Mid-Speed Fan Performance Results
While the Corator DS’ numbers are still decent, and better than the D14’s, it is quite obvious these dual tower cooling solutions need high speed, high static pressure fans perform well. The fin array certainly has been improved and tweaked to be more forgiving, but that is still a LOT of surface area to pull and push air through for one fan.
The improved fin array once again is giving this cooler an advantage over the D14. However, it still has a firm grasp on third to last place. We truly believe the less than optimal base could be the culprit here.
When the heat is turned way up we can see the D14 show the Corator who’s boss. The D14 may not like running in single fan mode, nor was it really designed to do so, but it still its execution is flawless. Compare this to the Corator DS, which WAS designed with a single fan in mind but the execution of the overall design leaves a lot to be desired.
2.6GHz
<img src="http://images.hardwarecanucks.com/image/akg/Air_Cooling/Corator_DS/nfp12_1300_266.jpg" border="0" alt="" />
3.42GHz
<img src="http://images.hardwarecanucks.com/image/akg/Air_Cooling/Corator_DS/nfp12_1300_34.jpg" border="0" alt="" />
3.8GHz
<img src="http://images.hardwarecanucks.com/image/akg/Air_Cooling/Corator_DS/nfp12_1300_38.jpg" border="0" alt="" />
