Old June 2, 2010, 09:35 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Coolink Corator DS CPU Cooler Review Comment Thread
Being the sister company of an industry heavyweight can't be easy but that's exactly what Coolink has lived with since their inception. Nonetheless, they have succeeded time and again in distancing themselves from the long shadow that Noctua casts and have forged ahead with innovative, well-priced heatsink designs. In this review we take a look at their Corator DS; a cooler which is supposed to cater to enthusiasts with high end performance while keeping the overall price at a reasonable level.
[ Read full article ]
Old June 2, 2010, 10:43 PM
burebista's Avatar
Thanks AkG, thorough review as usual.
Indeed Corator DS is a worthy HDT heatsink. Good job, both you and Coolink.
If it ain't broke... fix it until it is.
Old June 3, 2010, 07:44 AM
gingerbee's Avatar
does not look very well built at all but then again the first hdt was very cheap ( xigmatek )
Old June 4, 2010, 12:52 PM
SirDevon's Avatar
Wink
Page 6
"The heads of these bolts are octagonal shaped and fit snugly between the raised edges of the backplate that has been designed specifically to hold them in place."
a small nitpic..... hexagonal
just trying to help.. I hate when someone points these out to me though.
Old June 4, 2010, 02:12 PM
nice. like the coolers were you get to keep the standard backplate for amd.
i see installation wasnt too difficult, for a big tower cooler.
now, is it me or its doing marvelously well with low speed fans??? :)
Cons:
- Size and weight belie its limited cooling performance
- Base needs a lot more work on fit & finishing
- Can only mount a single fan
- Dual tower design really need two fans to reach its potential
- Very limited availability
Old June 4, 2010, 02:44 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Top number is sock fan result....the BOTTOM number is it in a "apples to apples" comparison against other coolers running a low speed fan. Very few stock fans will NOT do well when compared against an anaemic 900rpm fan ;)
Cons:
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Coolink Introduces its New Corator DS CPU Cooler SKYMTL Press Releases & Tech News 7 January 20, 2010 10:54 AM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
Coolink Silentator CPU Cooler Review Comment Thread SKYMTL Air Cooling 7 April 22, 2008 08:20 AM
