Feature Testing: Onboard Audio
Since fewer and fewer consumers seem to be buying discrete sound cards, the quality of a motherboard's onboard audio is now more important than ever. We figured that it was worthwhile to take a closer look at just how good the analog signal quality is on this new EVGA X99 Classified and compare it to the ASUS X99 Deluxe and ASUS Maximus VII GENE motherboards that we have recently reviewed. The EVGA features a dedicated Creative Core3D CA0132 quad-core audio processor, while the two ASUS models use Realtek's latest ALC1150 CODEC, although in two wildly different implementations. We are going to do this using both quantitative and qualitative analysis, since sound quality isn't really something that can be adequately explained with only numbers. To do this we have turned to the RightMark Audio Analyzer, basically the standard application for this type of testing. Since all the three motherboards support very high quality 24-bit, 192kHz audio playback we selected that as the sample mode option. Basically, what this test does is pipe the audio signal from the front-channel output to the line-in input via a 3.5mm male to 3.5mm male mini-plug cable, and then RightMark Audio Analyzer (RMAA) does the audio analysis. Obviously we disabled all software enhancements since they interfere with the pure technical performance that we are trying to benchmark.
As always, we used a mix of Grado SR225i and Koss PortaPro headphones, Westone UM1 IEMs, and Logitech Z-5500 5.1 speakers for our extensive listening period, and we are happy to report that the sound quality was very good to excellent depending on what hardware we were listening through. Obviously without a dedicated headphone amplifier - which is present on both ASUS models - the X99 Classified was not able to push our Grado headphones quite as loudly. Furthermore, the soundstage was noticeably smaller and less detailed than it was on the X99 Deluxe. Having said that, without a back-to-back listening session with all three motherboards it's impossible to declare an overall winner. As we have mentioned in the past, at this high level we suspect that your average user will be perfectly content with this motherboard's onboard sound quality and perhaps overjoyed by its gaming audio capabilities.
Although EVGA's audio implementation clearly achieved very solid numbers, we are still curious as to what effect the missing EMI shield on the Creative processor and the lack of a PCB audio separation line had on the overall results. Numbers don't tell the whole story though, and if you are a gamer you really have to take into account the powerful Creative software suite.
In the end, the dedicated Creative Sound Core3D quad-core audio processor should excite the gaming crowd, and is a real differentiating factor when compared to the endless sea of Realtek based onboard audio solutions on the market right now.
