Review Contents:
ASUS P5Q PRO P45 Motherboard Review
by MAC     |     July 28, 2008
Voltage Regulation
Our voltage regulation testing is compromised of two factors being tested. Since this ASUS motherboard provides 'Loadline Calibration', we will be testing the vCORE fluctuation with and without this feature enabled in the BIOS on our stable overclock. Intel specification outlines a droop in voltage for Intel processors when switching from idle to load conditions. This droop is referred to as Vdroop in the overclocking community and generally regarded as a bad thing because it requires setting a higher vCORE to make up for the droop that occurs at load. Loadline Calibration in the ASUS BIOS is basically an option to eliminate the Vdroop from occurring. So our testing will not only be showing the difference between the two different states of Loadline Calibration, but it will also let us know how well Loadline Calibration does at eliminating Vdroop.
The second prong of our voltage testing will be a look at the various voltages and the differences encountered between what is selected in the BIOS, what is reported by digital multi-meter (DMM). We have found five voltage read points on the motherboard so the vCORE, PLL, vFSB/VTT, vNB, and vDIMM will be recorded with the DMM. Both vCORE and vNB will be read from the underside of the motherboard at the output side of the corresponding inductor for each voltage supply. PLL and vFSB/VTT voltages will be read from points on the top of the motherboard. vDIMM will be read directly from an open DIMM slot using the VDD pin closest to the key. The ground point used for all readings will be a screw hole. Here are a few photos showing the various read points used.
Now that we have established where the read points are, let’s have a look at the results. In the chart below, vCORE (LLC) is the vCORE with Loadline Calibration enabled and vCORE will be with Loadline Calibration disabled. These measurements were taken at 7x400Mhz, the highest officially supported FSB, and the FSB that will most likely be used by those seeking mild overclocks. Everything else in the BIOS is set to auto. Here are our extensive findings:
As you can see…we have a lot to talk about, so let’s examine each voltage separately.
  • vCore: Overall, even without the benefit of LLC, this board displays good vCore regulation with minimal vDroop. The BIOS selections are within 3% of the actual readings for pretty much all of the voltages, which is quite commendable. At the auto setting, the vCore is set a little high, but it will allow novice users achieve respectable overclocks without fiddling with the vCore settings.
  • vCore (LLC): The solid vCore regulation obviously gets even better once LLC is enable. In fact, vDroop is eliminated and there’s actually a bit of vBoost under load. Quite impressive.
  • PLL: As you can see, the first two settings are set very high when compared to Intel’s recommended 1.50V ± 5%. However, there is no conclusive evidence that PLL can cause long-term harm to a CPU, and we can’t formulate our own opinion without long-term testing of PLL-related issues. Having said that, we recommend that users manually set this option to 1.54v just to be safe. Also, it is quite possible that the BIOS will lower this setting when a 45nm chip is detected.
  • vNB: Overall, we are very satisfied with the northbridge voltages, which display superior stability across the board. Once again there is a bit of overvolting at the auto setting, but it was likely implemented to ensure that all P5Q PRO’s would be able to achieve their FSB1600 specification without unnecessary user tinkering.
  • vDIMM: ASUS motherboards are well-known for overvolting the memory by between 0.06-0.10V, and we do not see any issues with this, as long as the user is aware that it is happening.
  • vFSB/VTT: From 1.24V onwards the VTT is perfectly acceptable. However, the auto and 1.20V settings are quite high. Recently, there have been countless debates about the effects of VTT on the long-term health of 45nm chips, and the general consensus is not to use over 1.40V on a 24/7 basis. However, once again, it is quite possible that the BIOS would lower the VTT to a more reasonable auto setting when it detects a 45nm chip.
Now let’s recap a few important facts. Every individual motherboard is different, and it is entirely possible that our sample is alone in displaying any and all of the above voltage characteristics. Also, the motherboard did not significantly overvolt the PLL and FSB/VTT voltages when using a 266Mhz and 333Mhz FSB, they remained at 1.55V and 1.22V respectively on the auto setting.
Now let’s have a look at a couple of OCCT vCORE charts over a two hour stress test.
vCORE w/Loadline Calibration Disabled
This result was with the processor set to 8x400Mhz with a 1.325 vCore. Overall, the regulation looks quite good. The slight vDroop is noticeable once the stress test actually kicks-in, but otherwise the fluctuations are quite minimal, and there are no zero worrisome spikes. Evidently, the eight-phase power design is doing it's job quite well.
vCORE w/Loadline Calibration Enaled
This time once the stress test kicks-in the motherboard actually increases the vCore by almost 0.01V, which should help ensure stability under heavy load. As you can see, once the test gets going the vCore is straight as an arrow until the last 5 minutes, when OCCT enters the low load monitoring stage.
March 14, 2010
The Republic of Gamers series from ASUS has always been known for being among the best in the industry and the Rampage motherboards are at the their forefront.  The new Rampage III Extreme will soon b...
March 11, 2010
ASUS hasn't been making much noise in the high-end AMD market as of late and has instead concentrated their new Republic of Gamers series motherboards towards Intel users.  That is all about to change...
March 3, 2010
ASUS has long been known for their Republic of Gamers series of motherboards and while they have products already in place for both of Intel's P55 and X58 platforms, they felt it was time to take thin...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/8783-asus-p5q-pro-p45-motherboard-review.html
Posted By Date
Ïðîäàâàì äúíî: P5Q PRO (P45) - BulForum.com Yesterday 01:16 PM
??????????? Overclockers.ru &bull; ???????? ???? - Asus P5Q (??? ???????????) ?? ??????? Intel <P45> + FAQ March 14, 2010 11:11 AM
???????? ????? ?????? Asus P5Q PRO - Data.BG ?????? March 8, 2010 01:29 PM
Asus CPU Parameter Recall (C.P.R). - [H]ard|Forum February 27, 2010 10:46 PM
The community of Hardcore computing - The LGA775 Motherboard Reviews February 23, 2010 12:33 AM
Core 2 quad q6600 do ==> 3.6 Ghz @ Slo-Tech February 21, 2010 10:18 AM
How to OC February 9, 2010 03:11 AM
Forum E-Iasi.com :: Vizualizare subiect - Vand placi baza - skt LGA775 - IASI : vanzari-cumparari-academice-evenimente-studenti February 2, 2010 11:44 PM
PCSTATS.com - PC Hardware Reviews and Guides - Get The 'Stats and Stay Informed! January 28, 2010 03:33 AM
Overclocking ??????? ?? p5ql-e asus ??? q9300 - ADSLgr.com January 23, 2010 09:07 AM
_&#8332;= The Q9550 Club =&#8332;_ [Please read first post] - Page 66 - Overclock.net - Overclocking.net January 22, 2010 03:55 PM
CPU Overclocking, Vcore MAX myths and truth - AnandTech Forums January 14, 2010 06:36 PM
Antec P180 Computer for sell ( E6300 Core 2 Duo CPU) January 7, 2010 02:22 PM
Need HELP! - Building - Desktops - Whirlpool Forums January 4, 2010 03:27 PM
Official Asus P45 Series Overclocking/Discussion Thread - Page 12 - VRForums - IT Show 2010 | The Most Happening IT & Singapore Lifestyle Community December 29, 2009 11:24 AM
For Sale: ASUS P5Q PRO *Read for more info* - iSTORYA.NET December 21, 2009 05:47 PM
Official Asus P45 Series Overclocking/Discussion Thread - VRForums - IT Show 2010 | The Most Happening IT & Singapore Lifestyle Community December 17, 2009 07:53 AM
"ASUS P5Q Deluxe discussion". - Page 190 - XtremeSystems Forums December 13, 2009 06:37 AM
How to OC - OCZ Forum December 1, 2009 03:58 PM
Load Line Calibration - AnandTech Forums November 7, 2009 10:44 PM
Asus P5Q Pro,auto voltages - Are all voltages increased when overclocking? - Some are,& I've now created a partial table - AnandTech Forums November 6, 2009 03:54 PM
"ASUS P5Q Deluxe discussion". - Page 84 - XtremeSystems Forums November 3, 2009 04:45 PM
Sold: [Canada] Q9550 + TRUE [SOLD] - Overclock.net - Overclocking.net November 3, 2009 03:45 AM
Intel Q9xxx and Xeon 33x0 Family October 21, 2009 08:25 PM
For Sale: [Canada] Q9550 + P5Q Pro + TRUE ($260 CDN) - Overclock.net - Overclocking.net October 16, 2009 10:24 AM
Le topic de l'overclocking [FINI !] - Page 47 - Canardpc.com October 5, 2009 11:21 PM
P5Q-Pro not restarting after changing BIOS settings - techPowerUp! Forums September 29, 2009 11:03 PM
Asus CPU Parameter Recall (C.P.R). - [H]ard|Forum September 13, 2009 08:50 AM
NCIXUS.com - Buy ASUS P5Q Pro ATX LGA775 P45 DDR2 2PCI-E16 CrossFire 3PCI-E1 2PCI SATA2 Sound GBLAN eSATA Motherboard - P5Q Pro. September 13, 2009 05:03 AM
360Mods Forums Xbox 360 Modding Xbox 360 Beginners/General Do I need new burner / dvd-rom drives? What other hardware? September 10, 2009 12:38 AM
Asus P5Q Pro Northbridge Cooler OK? - [H]ard|Forum September 8, 2009 05:17 AM
New P45 board. Which one? - XtremeSystems Forums September 5, 2009 02:41 PM
Q6700 + Asus Maximus 2 Formula - Page 2 - PureOverclock Forums September 5, 2009 03:53 AM
Overclocking the Q9550 on ASUS P5Q-E - Futuremark / YouGamers Forums August 31, 2009 06:45 PM
"VENTAS DE -=MandoxS=- MUCHOS PRODUCTOS, ENTRE Y APROVECHE =D - LANeros.com August 31, 2009 05:21 PM
AnandTech - Is 1.575 volts too high - QX6850 August 30, 2009 03:42 AM
Motherboards :: Intel Motherboards :: Socket 775 :: Asus P5Q PRO Socket 775 - Wintronic Computers Plus August 18, 2009 11:05 PM
The LGA775 Motherboard Reviews - Forums on the BleedinEdge August 9, 2009 02:08 PM
Decent Mobo for Q9550 and 4870x2 - Building - Desktops - Whirlpool Broadband Forums August 5, 2009 02:18 PM
[wts] ASUS P5Q PRO Intel P45 Motherboard August 4, 2009 01:37 AM
GA-EP45-UD3P vs. Asus P5Q Pro - ?????????? ?? ????? August 3, 2009 05:02 AM
Techgage - July 29th Tech Roundup July 31, 2009 04:07 PM
Le topic de l'overclocking [ça avance...] - Page 47 - Canardpc.com July 27, 2009 02:18 PM
high-tech - Portal July 26, 2009 08:16 AM
Nano gives atom food for thought - and then some - The Inquirer July 25, 2009 05:39 AM
AnandTech - CPU Overclocking, Vcore MAX myths and truth July 21, 2009 11:46 AM
Le topic de l'overclocking [Phase alpha pré-beta] - Page 47 - Canardpc.com July 20, 2009 04:00 PM
_&#8332;= The Q9550 Club =&#8332;_ [Please read first post] - Page 92 - Overclock.net - Overclocking.net July 17, 2009 05:42 AM
Asus P5Q Deluxe won't do 415x6 - Page 2 - Futuremark / YouGamers Forums July 13, 2009 01:06 AM
SweClockers.com - Forum: Officiella E8*00 Tråden July 11, 2009 08:07 AM
_&#8332;= The Q9550 Club =&#8332;_ [Please read first post] - Page 67 - Overclock.net - Overclocking.net July 10, 2009 05:45 AM
AnandTech - Finally upgrading my computer! July 6, 2009 02:30 AM
"ASUS P5Q Deluxe discussion". - Page 190 - XtremeSystems Forums July 4, 2009 07:46 PM
[wts] ASUS P5Q PRO P45 Motherboard July 2, 2009 07:54 AM
&bull; View topic - Ny maskin....igjen :P June 28, 2009 01:46 AM
SweClockers.com - Forum: Är det bara jag eller ser detta konstigt ut Corais 520 June 15, 2009 11:40 AM
ASUS P5Q PRO Motherboard - S775 - DDR2 - Retail - NEW! - eBay (item 180368764770 end time Jun-21-09 06:06:33 PDT) June 14, 2009 06:26 AM
ASUS P5Q PRO Motherboard - S775 - DDR2 - Retail - NEW! on eBay, also For Intel, Motherboards, Desktop PC Components, Computing (end time 21-Jun-09 14:06:33 BST) June 14, 2009 06:09 AM
fieldstar's motherboard Bookmarks on Delicious June 11, 2009 05:35 AM
Decent Mobo for Q9550 and 4870x2 - Building - Desktops June 11, 2009 04:18 AM
Official Asus P45 Series Overclocking/Discussion Thread - Page 9 - VR-Zone IT & Lifestyle Forum! June 6, 2009 02:33 AM
Official E6300/SLGU9 spec page from Intel appears. finally! - Page 7 - VR-Zone IT & Lifestyle Forum! June 5, 2009 10:29 PM
GUYS PLEASE HELP ME BEFOR I SHOOT MYSELF June 5, 2009 09:06 AM
ASUS Loadline Calibration - Page 2 - Overclock.net - Overclocking.net June 2, 2009 01:51 PM
Gigabyte GA-EG45m-DS2H Intel G45 board goes on sale in HK May 30, 2009 10:40 PM
2560x1600 need card - [H]ard|Forum May 23, 2009 04:07 PM
Futuremark - News - Newsarticle May 20, 2009 07:19 PM
GameSpot Forums - PC Hardware Discussion - Which Motherboard is Better??? May 20, 2009 10:40 AM
OverclockersClub Forums > New Mobo, P45 Or X48? May 18, 2009 06:43 PM
Ïðîáëåì ñ ïàìåò... - hardwareBG.com ôîðóì May 17, 2009 08:20 AM
We seem to have one for every other P5Q, so now heres a thread for the P5Q Pro! :D - XtremeSystems Forums May 15, 2009 09:42 AM
Çë½ÌÏÂÖ÷°å´ïÈËÃÇ£¬ÐµÄP5Q Pro£¬É趨VTT»òÕßNBµçѹµÄʱºò£¬×îµÍÖµ»¹»áÃÍì­Ã´£¿ - Ö÷°å¼¼ÊõÌÖÂÛÇø - µçÄÔÓ²¼þÐÂÉúÍøÉçÇø - ¹úÄÚ×îºÃµÄµçÄÔÓ²¼þ½»Ò×¼°¶þÊÖÖû»»¥¶¯Æ½Ì¨ May 8, 2009 10:55 AM
Im confused (first time builder)? - Yahoo! UK & Ireland Answers May 6, 2009 06:11 AM
Im confused (first time builder)? - Yahoo! Answers India May 6, 2009 05:08 AM
ËÒ ÃÕÇÔÇ p5q pro ¤ÃѺ - OVERCLOCKZONE Forums May 5, 2009 08:51 PM
Re: Re: EarthWatts 380 Õæ²»´í°¡ - δÃû¿Õ¼ä(mitbbs.com) May 4, 2009 08:35 AM
_&#8332;= The Q9550 Club =&#8332;_ - Page 67 - Overclock.net - Overclocking.net May 1, 2009 02:43 PM
_&#8332;= The Q9550 Club =&#8332;_ - Page 66 - Overclock.net - Overclocking.net May 1, 2009 02:08 PM
"ASUS P5Q Deluxe discussion". - Page 191 - XtremeSystems Forums April 30, 2009 12:43 PM
[??] 2160 G0 ???? 3.6 ??? ? ????. ?????. April 29, 2009 11:12 PM
techPowerUp! - The latest in hardware and gaming April 27, 2009 10:24 AM
ASUS P5Q Pro P45 Motherboard Review @ Hardware Canucks April 27, 2009 04:29 AM
» ASUS P5Q Pro P45 Motherboard Review April 22, 2009 07:06 AM
Need some help with my P5Q pro. - Overclock.net - Overclocking.net April 20, 2009 04:57 PM
Asus p5q pro or Biostar i45 - Overclockers Forums April 19, 2009 10:18 PM
AnandTech - P45 boards head-to-head comparison April 19, 2009 04:52 AM
The Mother Board :: View topic - ASUS P5Q Pro P45 Motherboard Review @ Hardware Canucks April 17, 2009 02:55 PM
NCIX.com - Buy ASUS P5Q Pro ATX LGA775 P45 DDR2 2PCI-E16 CrossFire 3PCI-E1 2PCI SATA2 Sound GBLAN eSATA Motherboard - P5Q Pro In Canada. April 16, 2009 05:02 AM
**Official P5Q Vanilla Discussion** - XtremeSystems Forums April 15, 2009 02:21 PM
OC help Q6600+asus p5q pro - Overclocking 'n' Modding - TechEnclave April 15, 2009 01:02 PM
AnandTech: System Buyers Guide: PCs for Under $1000 April 13, 2009 11:46 AM
Modded ASUS P5Q/Pro/Deluxe/Premium BIOS - Page 22 - XtremeSystems Forums April 11, 2009 11:55 AM
AnandTech - Q9650 on P5Q Overclocking issue April 11, 2009 06:35 AM
techPowerUp! :: Review Database April 9, 2009 10:42 PM
New Mobo, P45 Or X48? - OverclockersClub Forums April 9, 2009 05:41 PM
ASUS P5Q Pro P45 Motherboard Review April 8, 2009 04:39 AM
AnandTech - P5Q Pro Voltage Question April 7, 2009 06:55 PM
What voltage is my ram actually running at? - Overclockers UK Forums April 6, 2009 08:17 AM
AnandTech - Load Line Calibration April 5, 2009 08:49 PM
P5Q Pro Overclocking Guide? - Overclock.net - Overclocking.net April 5, 2009 06:12 PM
Motherboard with DDR2 and DDR3 compatibility? - Yahoo! Answers April 4, 2009 10:05 PM
Asus P5Q Series Owners Thread - Page 4 - Overclock.net - Overclocking.net April 4, 2009 07:45 PM
Asus P5Q-Pro w/ 4850 in crossfire question on Sata - [H]ard|Forum April 4, 2009 12:15 PM
ASUS P5Q Pro P45 motherboard - PCSTATS.com April 3, 2009 04:09 PM
Asus P5Q PRO Socket 775 P5Q PRO - Placas base INTEL Socket 775 April 3, 2009 02:17 PM
Asus P5Q Pro Northbridge Cooler OK? - [H]ard|Forum April 3, 2009 01:42 PM
low FPS: Socket 775 motherboard reviews April 3, 2009 12:01 PM
AnandTech - Asus P5Q Pro,auto voltages - Are all voltages increased when overclocking? - Some are,& I've now created a partial table April 3, 2009 11:16 AM
Untitled document April 3, 2009 09:46 AM
Overclocking the Q9550 on ASUS P5Q-E - Futuremark / YouGamers Forums April 3, 2009 09:27 AM
ASUS P5Q Pro P45 Motherboard Review - Madshrimps Forum Madness April 3, 2009 12:52 AM
NCIX.com - Buy ASUS P5Q Pro ATX LGA775 P45 DDR2 2PCI-E16 CrossFire 3PCI-E1 2PCI SATA2 Sound GBLAN eSATA Motherboard - P5Q Pro In Canada. April 2, 2009 10:39 PM
ASUS P5Q Pro P45 Motherboard Review April 2, 2009 04:39 PM
ASUS P5Q PRO need help to OC. : Intel Motherboard Forum April 2, 2009 04:31 PM
The ASUS P45 Owner's Club - Page 13 - techPowerUp! Forums April 2, 2009 01:40 PM
