BIOS Rundown p.2
BIOS Rundown
Moving over one more tab to the Advanced tab are a number of configuration subscreens for CPU, System Agent, PCH, SATA, USB, Onboard Devices, and APM. The CPU Configuration page contains CPU information as well as settings for hyper-threading and active cores.
The main subpage you will need under Advanced is Onboard Devices as this is where you can disable a number of devices to save CPU cycles when benching and speed up boot time. Also worth mentioning is the CPU Power Management Configuration page which has power management options as well as CPU Ratio and Turbo Mode.
The Monitor section contains the system temperature/power status, and adjustable fan settings. Since we are running a watercooling system without any fans attached to fan headers on the board, fan controls were all set to ignore or disable. Fan speeds and customizable based on temperature, RPM, or there are profiles included in the BIOS.
The Boot tab contains boot priority options and POST options. Here you can also change the default BIOS mode from EZ to Advanced. Moving over to the Tools tab there are several useful tools available including DRAM SPD Information, EZ Flash 2, and OC Profiles. DRAM SPD Information shows all installed memory with subsections showing SPD.
ASUS OC Profiles allow for saving customized OC Profiles suited for different situations. This is a very handy tool for any overclocker but keep in mind that if you flash your BIOS your profiles are gone. Last but not least we have EZ Flash 2. This utility is used for flashing the board’s BIOS from a in a safe and easy manner.
BIOS Rundown
