BIOS Rundown
BIOS Rundown
2011 is the year of the UEFI BIOS and ASUS has adopted it in style. The Rampage IV Extreme has one of the most advanced yet complex BIOS’ that we have ever seen and features capabilities such as support for boot drives above 2.2TB and mouse support for easy navigation. The BIOS we have used in this section is version 0067b, dated Nov 8/11. Since then there have been a few more versions to improve performance but the general layout is the same.
The first and main BIOS screen is the Extreme Tweaker page. This section contains a long list of subpages and overclockers will spend the majority of their time here. At the main section's top are there are profiles to get users started as well as an auto overclocking option titled CPU Level Up. CPU Level Up gives auto OC options of 4.017Ghz, 4.120Ghz, and 4.250Ghz for a 3960X chip. Further down are adjustable settings for BCLK, CPU Strap, Turbo, as well as subscreens for memory timings, power control, CPU settings, and GPU/DIMM POST.
Next up is a wide range of voltages and skews for the processor and memory. As you can see each channel of RAM has its own voltage settings. At the bottom of the page are four more subpages that include advanced settings for CPU, RAM, PCH, and VGA.
The DRAM Timing Control screen contains every memory timing imaginable and will be a dream come true for memory tweakers. There are literally five pages of memory timings as well as MCH Duty Sense and Slews available to users. At the top of the page there are four memory presets that make a good starting point if you know the memory chips you are dealing with.
The next section under Extreme Tweaker is DIGI+ Power Control whicj contains voltage settings and every overclocker will spend some time here. Voltage and current options for CPU, VSA, VTT, DRAM, and PCH are found within.
The next two pages are also subsections of the Extreme Tweaker section. CPU Performance Settings is where you find CPU Ratio, Speedstep, and Turbo. You can also set custom Turbo Mode Parameters such as power limits. GPU/DIMM POST contains two subpages as shown below.
GPU and DIMM POST pages show the video cards and memory in the system detected at POST and the speeds both are running.
The PCI-E Simulator tool is an interesting BIOS feature that shows you what bandwidth your video cards will run in a variety of different configurations. Changing these settings doesn't actually do anything other than give you info about the PCI-E lanes.
BIOS Rundown
