Power Consumption / Temperature Testing
For this section, every energy saving feature was enabled in the respective BIOSes and the Windows Vista power plan was changed from High Performance to Balanced.
For our idle test, we let the system idle for 15 minutes and measured the peak wattage through our UPM EM100 power meter.
For our CPU load test, we ran Prime 95 In-place large FFTs on all available threads for 15 minutes, measuring the peak wattage via the UPM EM100 power meter.
For our overall system load test, we ran Prime 95 In-place large FFTs on all available threads for 15 minutes, while simultaneously loading the GPU with OCCT v3.1.0 GPU:OCCT stress test at 1680x1050@60Hz in full screen mode.
As expected, the A6-3650 features very similar power consumption figures as the A8-3850, but given its slightly higher idle and load voltages it does draw a bit more wattage. As we mentioned in the launch article, we expected Llano to have lower power consumption due to its new 32nm manufacturing process, but its die does have a chart-topping 1.45 billion transistors, by far the most of any consumer-oriented processor.
Frankly though, this processor has a huge chunk of its die dedicated to graphics, and it was designed to be used in a simple system without a discrete GPU, so let’s take a look at the power consumption when using the IGP.
First let's restate that the Sandy Bridge chips in this graph have an almost unfair advantage in the form of the Intel DH67BL motherboard. This Intel-manufactured motherboard has unmatched idle power consumption, easily 10W less than comparable motherboards from the big three motherboard manufacturers. While the A6-3650's idle power consumption numbers are very good, they are a bit higher than the A8-3850's due to a higher idle voltage (0.456V vs. 0.444V). When you load up the CPU, power consumption rises greatly, and it’s not really competitive with its main competition, the Core i3-2100 series. Thankfully, the power consumption doesn’t rise much when you also tax the integrated GPU, so overall you end up with a system that should peak at about 150W max.
For the temperature testing, since we were not given a default cooler from AMD, we used a Thermalright Ultra-120 Extreme with a Thermalright TR-FDB-1600 fan. The ambient temperature was 22°C/72°F. The application used to monitor temperatures was HWiNFO v3.82-1300. Keep in mind that the thermal sensors in most modern processors are not really accurate at measuring idle temperatures, hence the very small delta between the room temp and the idle results.
Idle CPU + Idle IGP: The system was left to idle for 15 minutes.
Idle GPU + Load IGP: OCCT v3.1.0 GPU stress test was run at 1680x1050 for 15 minutes.
Load CPU + Idle IGP: Prime 95 In-place large FFTs was run for 15 minutes.
Load CPU + Load IGP: Prime 95 In-place large FFTs and OCCT v3.1.0 GPU stress test were run for 15 minutes.
AMD are known for making cool-running processors, and the A-series APUs appear to be no different.
Our A6-3650 sample was downright chilly when idle, and barely warmed up when we were fully loading the integrated GPU. Even when both CPU and GPU portions where loaded, the temperature just barely broke the 40°C mark.
Power Consumption
Temperature Testing
