Originally Posted by BootlegUsher I know that you wanted all the test platforms to be similar, so DDR3 1333 was used on all of them, but doesn't that hamper the A6 3650 quite a bit? Wouldn't it be fair to use the highest natively supported memory frequency on all the platforms? |
Native memory speed as defaulted to in all BIOS versions of every mobo is 1333 for Llano. Llano "officially supports" higher memory speeds but it doesn't run at those speeds without manually setting the divider in the BIOS.
Also, as you mentioned all platforms are tested at the same memory speeds in order to keep things consistent.
