| | | Author: MAC Date: January 2, 2011 Product Name: Intel Core i5-2500K & Core i7-2600K | | | Synthetic Benchmarks: SuperPI 32M / wPRIME 1024M Synthetic Benchmarks: SuperPI 32M / wPRIME 1024M SuperPi Mod v1.5 When running the SuperPI 32MB benchmark, we are calculating Pi to 32 million digits and timing the process. Obviously more CPU power helps in this intense calculation, but the memory sub-system also plays an important role, as does the operating system. We are running one instance of SuperPi via the HyperPi 0.99b interface. This is therefore a single-thread workload. wPRIME 2.03 wPrime is a leading multithreaded benchmark for x86 processors that tests your processor performance by calculating square roots with a recursive call of Newton's method for estimating functions, with f(x)=x2-k, where k is the number we're sqrting, until Sgn(f(x)/f'(x)) does not equal that of the previous iteration, starting with an estimation of k/2. It then uses an iterative calling of the estimation method a set amount of times to increase the accuracy of the results. It then confirms that n(k)2=k to ensure the calculation was correct. It repeats this for all numbers from 1 to the requested maximum. This is a highly multi-threaded workload.
