Synthetic Benchmarks
Lavalys Everest Ultimate v5.02
Everest Ultimate is the most useful tool for any and all benchmarkers or overclockers. With the ability to pick up most voltage, temperature, and fan sensors on almost every motherboard available, Everest provides the ability to customize the outputs in a number of forms on your desktop. We selected two of Everest's seven CPU benchmarks: CPU Queen and FPU Mandel. According to Lavalys, CPU Queen simple integer benchmark focuses on the branch prediction capabilities and the misprediction penalties of the CPU. It finds the solutions for the classic "Queens problem" on a 10 by 10 sized chessboard. At the same clock speed theoretically the processor with the shorter pipeline and smaller misprediction penalties will attain higher benchmark scores. The FPU Mandel benchmark measures the double precision (also known as 64-bit) floating-point performance through the computation of several frames of the popular "Mandelbrot" fractal. Both tests consume less than 1 MB system memory, and are Hyper-Threading, multi-processor (SMP) and multi-core (CMP) aware.
Everest Ultimate is the most useful tool for any and all benchmarkers or overclockers. With the ability to pick up most voltage, temperature, and fan sensors on almost every motherboard available, Everest provides the ability to customize the outputs in a number of forms on your desktop. In addition to this, the memory benchmarking utility provides a useful tool of measuring the changes to your memory sub-system.
ScienceMark v2.0
Although last updated almost 3 years ago, and despite its rudimentary interface, ScienceMark v2.0 remains a favorite for accurately calculating bandwidth on even the newest chipsets.
While interesting, these are all the synthetic benchmarks, so will the results be any different in real-life applications? Let's find out.
ScienceMark v2.0
