Gelid Tranquillo CPU Cooler Review
by AkG     |     March 15, 2010
Mid-Speed Fan Performance Results
2.6GHz
While not nearly as good as the results we saw at this heat level with other fans, the test results are still decent. We really are starting to get a handle on what the true capabilities of this cooler are and they are actually impressive. As we have said in the past this chart is stacked with only the best of the best, be it best value or best overall and this cooler is only being beaten by products costing more than it.
3.42GHz
It seems that our earlier supposition of the Gelid Tranquillo’s fin array being optimized for low speed fans was incorrect. The upside to this is that you get very, very good results out of the box….BUT if you need an even lower noise solution you are in for a tough go of it performance wise.
3.8GHz
About the only thing that saves this cooler from coming in last place (after the stock Intel cooler that is) is the fact that it has mass and efficiency to burn. That imperfectly finished, but solid copper, base with a good fin array is what allows this cooler to easily beat the Cooler Master Hyper 212+. This is no mean feat and while it does get beaten by all the others in the chart there is no shame in being beaten by the best of the best.
Latest Reviews in Cooling
October 12, 2011
September 29, 2011
July 14, 2011
