Enermax Revolution 85+ 1050W Power Supply Review
by Michael "SKYMTL" Hoenig     |     July 15, 2009
Temperatures & Acoustical Properties
Temperatures
Through higher efficiency comes less power lost to heat and the Revolution demonstrates that quite well. Even though it seems to present slightly higher idle exhaust temperatures than the HX1000, the Revolution reigned things in to handily win the contest. Let me tell you, a delta of 4°C may not look like much on paper but when it comes to your system dumping hot air into your room, it makes a hell of a difference.
Considering the hellish, ear-drum shaking amount of noise that comes from our test system’s two HD 4870X2 cards and the dual Panaflo monster fans on the CoolIT Boreas, it is a miracle I haven’t gone deaf. As you can imagine, this setup isn’t the best for proper acoustical testing but by placing my ear next to the unit, I was able to get a pretty good approximation of the noise it produces.
Even though the fan on the Revolution 85+ spins up quite a bit when running the higher wattage tests, it never becomes loud or annoying. From what I could tell, bearing noise is kept to a bare minimum and other than a muted hum; most people won’t even know that the fan on this unit is running. It also seems like Enermax’s Air Guard around the fan’s periphery almost completely eliminates the usual “whoosh” we have come to expect from fans operating in a closed environment.
Something else that should be mentioned is the fact that the fan controller will keep the fan spinning after the unit shuts down to dissipate any left-over heat.
Latest Reviews in Power Supplies
December 23, 2009
As prices for quality power supplies fall, products that were once out of reach are now accessible to consumers who are on a budget.  With the ever-increasing power demands of the most modern componen...
September 2, 2009
These days, power supplies seem to be a dime a dozen but when big-name manufacturers enter the market with their own units, people stand up and take notice.  That is why when we received XFX's brand n...
August 5, 2009
In the highly competitive power supply market, cheap products are a dime a dozen.  For the last few years, Corsair has shown us that well-priced power supplies can still perform above and beyond our e...
