GIGABYTE GA-MA770-UD3 AM2+/AM3 Motherboard Review
by MAC     |     July 27, 2009
Test Setup & Methodology
Test Platform:
Testing will occur on a Highspeed PC Standard Top Deck Tech Station and not in a traditional case. This allows easier access to the motherboard for the constant poking and prodding that is required during the reviewing process. The setup remained as pictured during the duration of the benchmarking and stability overclocking process.
Phenom II vs. Core 2 Duo Size Comparison - Click on image to enlarge
Overclocking Methodology
Although this is not a high-end model, we plan to test out the overclocking capabilities of the affordable, mainstream AMD 770 chipset. We hope to achieve some impressive overclocking results and are definitely going to find out what this motherboard is truly capable of. The overclocking section is definitely the part of our reviews that we take the most pride in, and we spend an excruciating numbers of hours testing, tweaking, failing, and succeeding in order to give you the best possible insight into each motherboard’s overclocking capabilities. After all, if you are anything like us, the overclocking section is the first (and often last!) part that you read when checking out a motherboard review.
For the purposes of this review, our overclocking efforts will primarily focus on three main areas: highest stable CPU bus overclock, highest stable CPU overclock, highest stable memory overclock, and overall system overclock.
In these four overclocking tests we put an emphasis on stability. While the question “What is stable?” could be debated endlessly, we have devised a methodology that combines a wide range of programs that test the stability of the entire system.
Here is the suite of applications that will be run in order to validate each of the overclocks:
  • Eight 32MB instances of SuperPi Mod 1.5 (ran at the same time)
  • 3+ hours of dual Prime 95 v25.6 using the Stress Testing Blend
  • 1 hour of OCCT Auto 1H Medium Data Set OCCT v3.0.1
  • 3+ hours of dual HCI MemTest in Windows using all available memory
  • Multiple loops of 3DMark 06 (30 minutes of looping the full tests each)
  • 1 hour of game play in Left 4 Dead & Crysis @ 1680x1050
Altogether, the above suite should provide enough stress testing to ensure a completely stable overclock, however we are always up for new suggestions. As always, no two systems are ever alike, so your results may vary. Also, overclock at your own risk! The Phenom II AM3 platform is brand new, and although we are somewhat conservative with our voltage estimates, there is always the possibility that you could damage any and all of your components. If you aren’t fully confident in what you are doing, feel free to stop by our forums and our helpful community will be glad to offer some assistance.
Benchmark Methodology
For this review, our benchmarking section will focus solely on the Gigabyte GA-MA770-UD3, in stock and overclocked configuration. The reasoning behind this approach is that there is a minuscule clock-for-clock performance difference between two motherboards that share an identical chipset and declaring one product a winner based on a 1% performance advantages seems futile to us.
We have outlined the two setups in the sample graph above. The blue results will indicate the performance at the BIOS defaults. The only change that was made to the BIOS is the disabling of Cool 'N Quiet. Every other setting was at the default that the BIOS sets. The red results are achieved using the highest stable overall system overclock for this particular setup.
For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology:
A) Windows is installed using a full format.
B) Intel Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed followed by a defragment and a reboot.
C) Programs and games are then installed followed by another defragment.
D) Windows updates are then completed installing all available updates followed by a defragment.
E) Benchmarks are each ran three times after a clean reboot for every iteration of the benchmark unless otherwise stated, the results are then averaged.
We have listed the benchmark versions on each graph as results can vary between updates. That should about cover everything so let's see what kind of numbers this motherboard puts up in the overclocking section and in our chosen suite of benchmarks.
January 24, 2012
January 2, 2012
November 20, 2011
