| by FiXT | April 20, 2009 | ||
| Memory Benchmarks Memory BenchmarksLavalys Everest Ultimate v5.00 Everest Ultimate is the most useful tool for any and all benchmarkers or overclockers. With the ability to pick up most voltage, temperature, and fan sensors on almost every motherboard available, Everest provides the ability to customize the outputs in a number of forms on your desktop. In addition to this, the memory benchmarking utility provides a useful tool of measuring the changes to your memory sub-system. ![]() After getting used to the humongous numbers that the Core i7 puts out, it was rather humbling to see the Phenom II's memory bandwidth. For both the stock and overclocked configurations, the system was running in dual-channel, unganged mode and with the memory frequency set to DDR3-1600. Likewise, the CPU/NB frequency was locked at 2000Mhz for all configurations, so there was no performance differential to be had from that area. As a result, it is no surprise that the bandwidth numbers are so similar. The only noteworthy improvement is the roughly 6% difference in copy speeds, but this is largely attributable to the higher CPU frequency. ![]() Due to the aforementioned similarity in the memory sub-system settings, the memory latency is effectively identical across the board. However, there was an unusual sweet spot at 3.2Ghz (16 x 200). There is no rhyme or reason for this anomaly, and it is only 1% lower than the other results, but we were able to repeat the results on numerous occasions. ScienceMark v2.0 Although last updated almost 3 years ago, and despite its rudimentary interface, ScienceMark v2.0 remains a favorite for accurately calculating bandwidth on even the newest chipsets. ![]() ScienceMark reveals a minor 4% increase in overall memory bandwidth between the stock and overclocked configurations. One way or another, despite benefiting from an integrated memory controller (IMC) and new DDR3 memory, no one is going to be breaking any memory-related records on this new AM3 platform. The M4A78T-E is obviously not to blame, it is simply a characteristic of the Phenom II's. | ||
