| by Michael "SKYMTL" Hoenig | May 24, 2009 | ||
| Overclocking Results Overclocking ResultsWhat do we consider a stable overclock? If the card can pass our test which involves a 20 minute loop of 3DMark06, 30 minutes of playing Far Cry 2 and an additional 30 minute gameplay sequence in Left 4 Dead, it is considered stable.Since overclocking can vary from one card to the next within the same family of cards, you should be aware that these results will not be considered when voicing our final opinions about these four cards. As such, we will show you the final overclocking results but leave our opinions to ourselves and let you guys form your own conclusions. BFG GTX 275 OC Final Overclocks Core: 681Mhz Shader: 1513Mhz Memory (DDR): 2560Mhz EVGA GTX 275 FTW Final Overclocks Core: 713Mhz (unable to attain stability past stock speeds) Shader: 1512Mhz Memory (DDR): 2636Mhz EVGA GTX 275 1792MB Final Overclocks Core: 692Mhz Shader: 1535Mhz Memory (DDR): 2392Mhz Gigabyte GTX 275 Final Overclocks Core: 709Mhz Shader: 1573Mhz Memory (DDR): 2598Mhz MSI GTX 275 Twin Frozr OC Final Overclocks Core: 725Mhz Shader: 1607Mhz Memory (DDR): 2550Mhz Sparkle GTX 275 PLUS Final Overclocks Core: 711Mhz Shader: 1580Mhz Memory (DDR): 2602Mhz | ||
