| by 3oh6 | April 21, 2009 | ||
| Heat & Acoustical Testing Heat & Acoustical TestingWe are going to be limited to simply testing the PWM temperatures of the EVGA X58 3X SLI Classified despite many public cries for EVGA to implement NB temperature monitoring from within Windows. The same was the case with the original EVGA X58 board but the BIOS engineers either couldn't, or couldn't have been bothered to allow the NB temperatures - which can be monitored in the BIOS - to be available for monitoring by software in Windows. The NB temperature sender shares time with the off-die CPU temperature sender and only one can send data to the system in Windows. In the BIOS, the system alternates reading between CPU and NB temperature. All of us EVGA X58 users have been asking for an option in the BIOS to select either NB or CPU temperature data to be read while in Windows but to no avail. ![]() As soon as EVGA started to release pre production images of the Classified cooling, it became apparent that they spent a lot of time in designing the heat sinks. The north bridge is covered by a large, but not too large as seen during the installation section, mass of cooling fins connected with a small network of heat pipes. The heat pipes lay over top of the north bridge and the south bridge heat sink conglomerating within the mass of cooling fins transferring the heat from the motherboard to the cooling fins for dissipation. As we can see in the photos above, the thermal paste application is quite good on the heat sinks. ![]() The PWM heat sink is similar in idea to the original X58 SLI, but significantly different in design. The larger heat pipe travels across the PWM area and instead of folding up in a U shape, it curls through the entire assembly of cooling fins providing much more contact with the cooling fins to dissipate the heat. This design has also allowed for a shorter heat sink on the PWM area allowing much more room around the CPU socket for large CPU coolers. We never had problems with the original X58 3X SLI motherboard, but it did slightly limit some fan placement on the Thermalright Ultra-120 eXtreme cooler. This new PWM heat sink is completely out of the way and a much nicer design in our opinions. ![]() On the left above we have a single 120mm fan pushing air through the Ultra 120-Extreme, and on the right we have our normal three fan setup with the TRUE utilizing two fans in push/pull, and a third ventilating the memory at the same time as the north bridge heat sink. We utilized our 24/7 overclock again for the PWM testing to push the board and quickly found out that the passive cooling might not be enough for a completely static setup.
Obviously the fact that we couldn't run the 20 minute stability test without the additional fans tells the whole story. The PWM charts above simply cement the fact that the passive cooling really does take a beating when pushed on the Classified. Ambient temperature was around 23-24C the entire time during testing so we aren't even in a hot case where temperatures could be much higher. It really does indicate that at some point, there needs to be air flow going over the NB/PWM heat sink assemblies if you are really pushing a system. This is again pretty disappointing because the entire culture behind this motherboard is overclocking. The EVGA forums are already in an uproar about having to add additional cooling to the north bridge heat sink so head over there for some tips if you run into an overheating situation. | ||
