| by 3oh6 | February 22, 2009 | ||
| Stability Testing & Overclocking Stability Testing & OverclockingThere is no point in me wasting my hot air on explaining our stability testing methodology, I blow enough hot air in the forums, so here is a cut and paste job from previous memory reviews to explain what we consider stable at HWC. Stability Testing MethodologyMemory stability, what constitutes stable? What is not considered stable? These questions get hotly debated in enthusiast forums all over the internet like little brush fires on the fringe of an inferno that play havoc with forest fire crews. Everyone has their own opinion about stability, especially when it comes to memory stability. For some, stable means they can do whatever it is on their computer without it crashing, blue-screening, or restarting; whether that means gaming or just surfing the internet. To this user, stable means simply using the computer as they normally would. ![]() Of course, that is not what we would call stable and we do a lot more thorough testing before labeling a memory frequency/timing stable. One of the toughest types of programs on a system has been found to be distributed computing projects such as Rosetta@Home, Folding@Home, World Community Grid, and more. Running 24/7 crunching for one of these great causes is a sure way to find holes in a system if there is truly some instability, unfortunately it takes a considerable amount of time to use them for stability testing so we use the list of programs below to all but guarantee the system to be 24/7 distributed computing stable:
As we have said, stability testing is a fairly fluid discussion. There are a million ways to properly test an overclock for stability. The above recipe we have found to bake a pretty solid and consistent cake and like to think it is a pretty good method for testing 24/7 overclocks of memory and a system. With memory involved in today's overclocking, the modules themselves aren't the only component being pushed. With the Intel i7 processor housing the memory controller now instead of the chipset, the CPU used in running a kit of memory over 900MHz at 7-8-7 is going to play a key role. This is even more evident when we start to approach the 1000MHz mark. Processor voltages like VTT are going to play a huge role in overclocking and balancing all of these with cooling is going to be tough. At some point, the processor is going to run out of gas with just air cooling before these Corsair Dominator-GTs do. Keep this in mind when looking at the results. Specification Stability Testing After the little rant earlier about lack of XMP support, stability testing at the specified timings and frequency obviously involved a little setting manipulation in the BIOS of the DFI X58-T3eH8 and the EVGA X58 SLI. Both boards were rather simple to get setup and running for an experienced user like myself, but for the average person, there will be a bit of a learning curve. Rumors on the internet were that we would run into one major speed bump with the EVGA X58 SLI as it was reported not to run the 2:14 ratio so we would have to go with the 2:12 ratio and increase the BCLK. This wasn't the case in any way, shape, or form. Like the DFI X58-T3eH8, we simply had to go in and adjust a couple voltages, manipulate the settings to get DDR3-1866 7-8-7-20 @ 1.65v running and we were off to stability testing. Click for full size screenshot... ![]() Both setups required pretty much identical voltages as far as VTT goes to get the systems stable. The key to high memory overclocks with the Dominator-GT memory, or any DDR3 on the Core i7 platform, is the VTT or sometimes incorrectly referred to as QPI voltage. This voltage setting is what powers all things on the processor that aren't the actual core, like the memory controller. Every processor is going to require a different amount of VTT in order to get this kit stable at DDR3-1866 7-8-7-20 but we found that both of the i7 965EE processors we used today required about the same. The EVGA screenshot is a little misleading as it shows a VTT of 1.400v set in the BIOS, but that actually equates to 1.35v when measured by a DMM. This is about the same VTT that the DFI X58-T3eH8 required as seen in the screenshot. The Everest reported voltages for the DFI shown in the screenshot are pretty much bang on to what is measured with a DMM. The EVGA voltage readings are pretty far off so we opted to show what voltages were set to in the BIOS through E-LEET. Stability Overclocking: The overclocking section of this Dominator-GT review is going to be a little flat. Simply put, this kit of memory is already so highly clocked at the specified ratings, that they really are pushing the limits of the Intel i7 processor. As we mentioned earlier, the memory controller is now on the processor die instead of the north bridge like Intel processors of past. Some weaker processors are going to have trouble pushing memory much past DDR3-2000, let alone 3x2GB at ultra tight timings like 7-8-7 without excessive voltages. ![]() Before we discuss what is shown above, why don't we address what is not. We don't have any results listed above for looser timings than the rated 7-8-7. The reason for that is quite simple; the tight timings of 7-8-7 outran our processor with air cooling, or so we suspect. Our system simply can't handle any higher stable clocks than what this kit was willing to offer at the tight timings of 7-8-7. We didn't even have to go up to our self imposed limit of 1.75v for the 7-8-7 clocks. This is assumed to result from a lack of our processors ability to stably clock the unCore frequency much past 4000MHz. At the same time, the memory could simply be out of gas. Further testing with sub-zero cooling and observation of the memories scaling with stability taking a back seat will provide more evidence to what held us back here. Click for full size screenshots... ![]() It is now time to turn this rather impressive overclocking display pu on by the Dominator-GTs into some benchmark results. We will be utilizing the results of the above overclocking to come up with an interesting comparison for the benchmark suite. With the versatility in frequency and timings available from the Dominator-GT, there really is no lack of possibilities for us to test, but we think we came up with something that will provide some insight into memory performance for end users. | ||
| Latest Reviews in RAM | |||||||||
