Categories
Review Contents:
Gigabyte GA-EP45-UD3P P45 Motherboard Review
by MAC     |     October 30, 2008
Overclocking Results
As evidenced by the introduction of the Extreme Series motherboards and the fact that they hosted a massive overclocking competition, it is clear that GIGABYTE are intently focused on the needs and wants of the overclocking community. As a result, we were definitely looking forward to testing out the EP45-UD3P's capabilities. In particular, we were interested in whether the Ultra Durable 3 features would truly result in tangible overclocking benefits.
When a new motherboard is released, the immaturity of the BIOS is often the limiting factor when it comes to overclocking. Regrettably, this was also the case with the EP45-UD3P with the first release F4 BIOS. As you will see below, the stable overclocking results are by no means bad, but they are not quite as good as we achieved with the more mature EP45-DQ6. Having said, this model's potential is definitely apparent, and once the BIOS is tweaked a little further this will be an overclocking monster.
Before continuing, please note that MemSet misreports the memory type and the memory clocks, therefore rely on CPU-Z and Everest instead.
Highest Stable FSB & Memory Overclocking
Click for full size…
Our regular readers will notice that for this review we have combined our "Maximum FSB Stability Overclocking" and "Maximum Memory Stability Overclocking" into one section. The reason for this unique change is simply due to the fact that our highest stable front-side bus speed allowed us to max out the Micron PC2-5300 (D9GMH ICs) modules that we use in our Test Setup.
As you can see, we were able to achieve a very respectable 515Mhz FSB at 1.34vNB with a relatively modest 1.34 VTT and 1.61 PLL voltages. While the key to our success was careful tweaking of the CPU Reference and MCH Refence voltages, a similar result could also be achieved by leaving all the settings on AUTO. However, above 500Mhz, the VTT and PLL voltages are automatically set to a stratospheric 1.60V and 1.85V, respectively. Although we knowingly stress-tested with these voltages for approximately 100 hours with no apparent consequences, we most definitely do not recommend them for long-term use. Take the time to tweak the CPU Reference and MCH Refence and you will achieve high FSB clocks with lower voltages.
Now the reason that we were limited to a 'mere' 515Mhz is due a consistent failure to pass SuperPI 32M at higher speeds. No matter how much voltage we used and how much tweaking we did, SPi 32M would not successfully complete three times in a row above 515Mhz. We could run loops of 3DMark 2001 at up to 585Mhz FSB and even pass OCCT 2 hours at 545Mhz, but SuperPI 32M would nevertheless fail. In our discussions with Gigabyte, we were told that this was a known issue and that an improved BIOS would be released very shortly.
Highest Stable Overall Overclocking
As like the higher-end EP45-DQ6, we have no qualms recommending the EP45-UD3P for 24/7 500Mhz FSB use. We were able to achieve this fairly lofty front-side bus speed at only 1.26vNB, and at this speed and voltage the northbridge and MOSFET coolers barely get warm to the touch. By any measure, a 4.0Ghz/500Mhz FSB/DDR2-1200 system is extremely fast, and nowadays it is remarkably easy to achieve too. We will be using these clock speeds as the overclocked configuration in the subsequent benchmarking section.
Since competitive benchmarking and overclocking is becoming such a popular activity, we have decided to include two new headers to our Overclocking Results section, Maximum Benchable FSB and Maximum Benchable Memory. Both of these will demonstrate the overclocking results we achieved at the razor's edge of stability. In order to qualify, an overclock must simply pass Everest Cache & Memory Benchmark and SuperPI 1M. This will reveal our motherboard's absolute maximum capabilities, without being quite as useless as mere suicide screenshots. Needless to say, unless you are fully willing to damage your components, don't try to recreate the results you see below.
Maximum Benchable FSB Overclocking
As we stated in the intro to this section, the EP45-UD3P has the potential to be a monster overclocker and this certainly supports that claim. 610Mhz FSB at 1.54vNB and a Performance Level of 10 is a terrific result on air, especially since it was accomplished with the stock NB cooler and thermal paste.
With some extreme cooling and a Core 2 Duo E8600, I wouldn't be surprised to see this motherboard achieve some top SPi 1M times.
Maximum Benchable Memory Overclocking
One of the benefits of the new 2 oz copper layers was said to be improved memory overclocking, and Gigabyte have increased the highest supported memory speeds from DDR2-1333 up to DDR2-1366+. While this may seem like overkill to many of you, there are in fact a few memory kits that are well-known for reliably hitting such speeds, like Team Group Xtreme PC2-10400 and Crucial Ballistix PC2-6400/PC2-8000/PC2-8500 (double-sided .16FD5 versions). Armed with a new set of these Ballistix modules, we were fully commited to testing out this DDR2-1366 claim. However, as you can see, sanity kicked in and we decided to settle on DDR2-1333, which is still extremely impressive. Clearly, anyone with good modules and an equal dose of courage and voltage can achieve some stupendous memory overclocks with the EP45-UD3P. Once again, we fully expect to see some DDR2 world records achieved with this model.
Well now that we have finished torturing this motherboard, let's see how it actually fares in benchmarks.
March 14, 2010
The Republic of Gamers series from ASUS has always been known for being among the best in the industry and the Rampage motherboards are at the their forefront.  The new Rampage III Extreme will soon b...
March 11, 2010
ASUS hasn't been making much noise in the high-end AMD market as of late and has instead concentrated their new Republic of Gamers series motherboards towards Intel users.  That is all about to change...
March 3, 2010
ASUS has long been known for their Republic of Gamers series of motherboards and while they have products already in place for both of Intel's P55 and X58 platforms, they felt it was time to take thin...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/10885-gigabyte-ga-ep45-ud3p-p45-motherboard-review.html
Posted By Date
-- GIGABYTE -- Ultra Durable 3 Motherboards March 11, 2010 04:00 PM
P:gigabayte ep45 ud3p - PC Ekspert Forum January 28, 2010 03:39 AM
Gigabyte GA-EP45-UD3P Motherboard Review - Futuremark / YouGamers Forums January 26, 2010 07:19 AM
ЃyGIGABYTEЃzGA-EP45ѓVѓЉЃ[ѓY Part3ЃyUD3Ѓz January 25, 2010 02:15 PM
Desktop Utils (QuickBoost / TurboV) vs. BIOS - AnandTech Forums January 24, 2010 01:05 PM
VEDIDO CERRAR.GRACIAS***P-45 GIGABYTE+ PATRIOT VIPER 8500 2 gb - Foros de CHW January 7, 2010 06:39 PM
Gigabyte EP45-UD3P - Overclockers Forums January 2, 2010 09:46 AM
Essence or Forte/HTHD on a GA-EP45-UD3P, PCI-e x1 (Will it Fit?) - Head-Fi: Covering Headphones, Earphones and Portable Audio December 22, 2009 11:31 AM
Gigabyte EP45-UD3 Series Owners Guide - Page 30 - Overclock.net - Overclocking.net December 21, 2009 05:43 PM
Gigabyte EP45-UD3 Series Owners Guide - Page 835 - Overclock.net - Overclocking.net December 19, 2009 11:28 AM
XtremeSystems Forums - ** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P December 15, 2009 02:18 PM
P-45 GIGABYTE+ PATRIOT VIPER 8500 2 gb - Foros de CHW December 14, 2009 09:26 PM
INTEL Q9550+ P-45 GIGABYTE+ PATRIOT VIPER 8500 2 gb - Foros de CHW December 10, 2009 01:39 PM
Gigabyte EP45-UD3 Series Owners Guide - Overclock.net - Overclocking.net December 9, 2009 05:49 PM
Q9550+gigabyte p-45+viper 2 gb - Foros de CHW December 9, 2009 08:18 AM
Review specs for my new build - AnandTech Forums November 30, 2009 05:39 AM
Mercadete Intel C2D VGA's HD DDR2 November 8, 2009 02:18 PM
AnandTech - Current choice of CPU coolers October 25, 2009 09:05 AM
Gigabyte EP45-UD3P Owners Guide - Page 30 - Overclock.net - Overclocking.net September 28, 2009 04:26 AM
techPowerUp! - The latest in hardware and gaming September 14, 2009 01:28 PM
Gigabyte ga-ep45-ud3P motherboard - Page 6 - [H]ard|Forum September 12, 2009 11:40 PM
** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P - Page 182 - XtremeSystems Forums September 6, 2009 06:20 AM
[WTS] Used Gigabyte EP45-UD3P (RM430) August 29, 2009 10:40 AM
Дъна с P45 чипсет - Страница 78 - hardwareBG.com форум August 26, 2009 06:35 AM
-- GIGABYTE -- Ultra Durable 3 Motherboards August 24, 2009 01:52 PM
GA-EP45-UD3P - Won't boot with 450FSB - Page 55 - TweakTown Forums August 19, 2009 09:06 PM
Audio Asylum Thread Printer August 13, 2009 01:33 AM
Can someone explain Gigabyte model number nomenclature? - Page 5 - Overclock.net - Overclocking.net August 12, 2009 05:03 PM
Дъна с P45 чипсет - Страница 78 - hardwareBG.com форум August 11, 2009 01:56 PM
Futuremark - News - Newsarticle August 8, 2009 02:23 AM
Cool, quiet, fast & sexy - long road to enlightment - Page 8 - TweakTown Forums August 7, 2009 02:34 PM
info_drip 200810 August 7, 2009 09:41 AM
** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P - Page 6 - XtremeSystems Forums August 6, 2009 05:22 PM
-- GIGABYTE -- Ultra Durable 3 Motherboards August 6, 2009 04:58 PM
Gigabyte Ga-Ep45-Ud3p Motherboard Review | CPU, Motherboards August 4, 2009 04:01 AM
Gigabyte GA-EP45-UD3P Motherboard Review July 23, 2009 03:41 PM
ўНаКХВ§¤№гЄй GA-EP45-UD3P - OVERCLOCKZONE Forums July 22, 2009 02:18 AM
Gigabyte GA-EP45-UD3P Socket 775 GA-EP45-UD3P - Placa Base July 22, 2009 01:20 AM
The LGA775 Motherboard Reviews - Forums on the BleedinEdge July 19, 2009 05:41 AM
Gigabyte GA-EP45-UD3P P45 Motherboard Review - X48, Motherboards and Memory July 17, 2009 08:31 PM
Review of Gigabyte GA-EP45-UD3P, Review Gigabyte GA-EP45-UD3P - Mainboards - Page 3 of 4 July 14, 2009 09:35 AM
What chipset for a q9550? - Overclock.net - Overclocking.net July 13, 2009 12:32 PM
Discussion- Gigabyte's new Ultra Durable 3 technology - Topic Powered by Eve For Enterprise July 13, 2009 01:54 AM
Review of Gigabyte GA-EP45-UD3P, Review Gigabyte GA-EP45-UD3P - Mainboards - Page 2 of 4 July 8, 2009 10:31 PM
Gigabyte GA-EP45-UD3P P45 Motherboard Review July 7, 2009 01:55 AM
Blue's News: Story - Hardware Reviews July 5, 2009 07:39 PM
[15-10-2008 ] Novas motherboards Gigabyte P45 Ultra Durable 3 - Page 3 - • PCDiga - Fуrum (www.pcdiga.net) • PCDiga - Loja (www.pcdiga.com) • July 3, 2009 05:08 AM
Gigabyte EP45-UD3P Owners Guide - Page 362 - Overclock.net - Overclocking.net July 2, 2009 03:10 PM
Mushkin RAM Not Recognized Correctly (Help!) - OverclockersClub Forums June 27, 2009 06:49 PM
NCIX.com - Buy Gigabyte EP45-UD3P ATX LGA775 P45 DDR2 2PCI-E SATA2 RAID HD Sound 2GLAN 1394A CrossFireX Motherboard - GA-EP45-UD3P In Canada. June 27, 2009 04:44 AM
Hight PerformanceSV (Ventas): VENDIDO!!! MOTHERBOARD GIGABYTE GA-EP45-UD3R (Oferta Gamer). June 26, 2009 07:16 PM
-- GIGABYTE -- ??????????? June 22, 2009 06:44 AM
S775 motherboard recommendations? - bit-tech.net Forums June 22, 2009 03:39 AM
New build configuration. Comment Plz - Building - Desktops - Whirlpool Broadband Forums June 11, 2009 06:43 AM
e8600 crazy overclock or just normal - Guru3D.com Forums June 4, 2009 05:57 AM
DailyTech - 10/31/2008 Daily Hardware Reviews May 31, 2009 01:16 AM
is my E8500 OC Stable? - Page 4 - Overclock.net - Overclocking.net May 25, 2009 02:21 AM
Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P - ??? ????? ????? May 23, 2009 12:22 AM
» Gigabyte GA-EP45-UD3P Motherboard Review May 15, 2009 03:30 AM
GIGABYTE GA-EP45-UD3P LGA 775 Motherboard May 14, 2009 05:27 PM
Gigabyte GA-EP45-UD3R ATX Intel Motherboard May 14, 2009 11:15 AM
Gigabyte ga-ep45-ud3P motherboard - Page 6 - [H]ard|Forum May 13, 2009 10:13 AM
Gigabyte ep45t-ud3p - XtremeSystems Forums May 10, 2009 10:25 AM
Friday Morning Roundup :: TweakTown May 10, 2009 01:48 AM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking May 8, 2009 09:25 AM
GIGABYTE GA-EP45-UD3P Findings / Review - PC Perspective Forums May 6, 2009 01:28 PM
News at Overclockers Online May 6, 2009 06:00 AM
Orthos Blend Fails. Small FFT Fine - OverclockersClub Forums May 4, 2009 04:06 AM
Hight PerformanceSV (Ventas): VENDO GIGABYTE GA-EP45-UD3R (Oferta Gamer) April 29, 2009 01:37 PM
Gigabyte ep45t-ud3p - XtremeSystems Forums April 26, 2009 09:53 PM
Great mobo around $170 - XtremeSystems Forums April 26, 2009 06:01 PM
Gigabyte GA-EP45-UD3P P45 motherboard - PCSTATS.com April 24, 2009 05:41 PM
Gigabyte GA-EP45-UD3P P45 Motherboard Review - Hardware Canucks April 24, 2009 05:27 PM
-- GIGABYTE -- Ultra Durable 3 Motherboards April 24, 2009 07:24 AM
** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P - Page 111 - XtremeSystems Forums April 21, 2009 10:30 AM
Gigabyte EP45-UD3P Owners Guide - Page 32 - Overclock.net - Overclocking.net April 19, 2009 12:16 PM
Looking for awesome overclocking mobo.. - Building - Desktops April 19, 2009 03:18 AM
Computer Audio Asylum April 18, 2009 08:03 AM
Computer Audio Asylum - RE: Why not one of Giga's new 2-oz. mobos? - abysstw - April 18, 2009 at 01:41:24 April 18, 2009 01:53 AM
Gigabyte GA-EP45-UD3P Motherboard Review April 17, 2009 09:45 AM
** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P - Page 110 - XtremeSystems Forums April 15, 2009 08:48 AM
** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P - Page 7 - XtremeSystems Forums April 14, 2009 09:41 AM
Gigabyte GA-EP45-UD3P Motherboard Review @ Hardware Canucks April 13, 2009 04:07 PM
My DFI LT X38-T2R ... - PCSTATS Forum April 12, 2009 01:16 PM
** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P - Page 6 - XtremeSystems Forums April 11, 2009 06:54 PM
Mainboards durchsuchen | 3DCenter.org April 11, 2009 07:26 AM
-- GIGABYTE -- Ultra Durable 3 Motherboards April 11, 2009 01:50 AM
** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P - Page 116 - XtremeSystems Forums April 10, 2009 11:07 PM
- !DEAD! - GIGABYTE GA-EP45-UD3P Intel Socket 775 Motherboard, $99AR/ACC + free shipping + some combos - SlickDeals.net Forums April 8, 2009 08:40 PM
Gigabyte EP45-UD3P Owners Guide - Overclock.net - Overclocking.net April 7, 2009 11:30 AM
Дъна с P45 чипсет - Страница 44 - hardwareBG.com форум April 7, 2009 10:33 AM
Gigabyte EP45-UD3P Owners Guide - Page 169 - Overclock.net - Overclocking.net April 6, 2009 07:27 PM
Need advice on new Motherboard - PCSTATS Forum April 6, 2009 12:04 PM
Gigabyte GA-EP45-UD3P Motherboard Review April 6, 2009 10:53 AM
techPowerUp! :: Review Database April 6, 2009 09:05 AM
Gigabyte GA-EP45-UD3P P45 motherboard April 5, 2009 07:23 PM
UD3P, what are the default CPU FREQ and Multiplier settings for this board? - HTFC Forums April 5, 2009 09:06 AM
Gigabyte GA-EP45-Extreme Appreciation Society - Page 3 - Overclockers UK Forums April 5, 2009 06:01 AM
Gigabyte GA-EP45-UD3R Living Review - Page 6 - Clunk's Forums. April 5, 2009 03:39 AM
GIGABYTE - 2 oz Copper PCB - Ultra Durable 3 - X58 - P45 motherboards April 4, 2009 01:44 PM
Gigabyte GA-EP45-UD3R Living Review - Page 5 - Clunk's Forums. April 3, 2009 02:22 PM
Gigabyte EP45-UD3P - Overclockers Forums April 3, 2009 01:21 PM
Gigabyte EP45-UD3P Overclocking Guide - Overclock.net - Overclocking.net April 3, 2009 12:59 AM
SATA burners compatible with AHCI : DVD Writers April 2, 2009 11:03 PM
P45 Asus vs. P45 Gigabyte... at same price - [H]ard|Forum April 2, 2009 04:45 PM
Gigabyte ga-ep45-ud3P motherboard - Page 22 - [H]ard|Forum April 2, 2009 04:09 PM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - Gigabyte GA-EP45-UD3P April 2, 2009 02:56 PM
