Old December 7, 2018, 02:26 PM
Mr. Friendly's Avatar
Default is there a good single fan AiO optoin?
I don't think I'm going to have the space for a 240 or 280 rad, so wondering if there are any good 120 or 140 AiO that could handle overclocking a 7600K.
thoughts / recommendations?
Old December 13, 2018, 10:41 AM
Corsair h60 or h80? my h60 held up a 4.6ghz oc on my 3770k
Old December 13, 2018, 10:46 AM
FreeKnight's Avatar
H80i V2 is doing well on a 4690k on my bedroom HTPC system. Admittedly I'm not OC'ing it at the moment, but it's idle is in the high 20s in a case that's not exactly ideal for airflow.
Old December 14, 2018, 05:23 PM
rjbarker's Avatar
I have a Corsair H60 on my 9900K (open bench) set up in push / pull.....9900K under load at 5Ghz (all cores) had only a couple of cores at 71c...the rest mid 60's....great little AIO
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old December 15, 2018, 11:24 AM
what were you stress testing for full load? two of my friends had their 9900K's @ 5ghz and stress testing with Prime 95 and they would throttle when they hit 100C. they had 240 AiO systems too.
Old December 15, 2018, 02:24 PM
rjbarker's Avatar
Mr Friendly....have your friends re-apply thermal paste (using the best)...and secure Block / Pump....set up there 240 AIO's with additional fans (push / pull) also assuming they have there present set ups to draw fresh air in over the rad (vs exhaust warm case air out over the rads)...
Cinebench repeatedly and P95 Small FFT.....I set the push / pull fans to Maz 1200 RPM....so your friends are having throttling issues with a 240 AIO ???? I would check the install and paste.....that aint right ...or what kind of vCore are they pushing??? Im using Adaptive Mode 1.225v for 5 Ghz...
So playing around a bit more...found I was able to bump this chip up to 5.1 Ghz and drop the vcore...Adaptive Mode (still figuring this out as I was previously used to using Offset Mode on my RIVE)...set to 1.215v v idle is 1.305vv and under load is 1.27v ....could bump the LLC up another notch (presently on "6")...but temps for this cooler are amazing ...again H60 (new) with High Static Corsair Fan (leftover from my WC gear) set up in push / pull....temps peak running a few benchmarks around 80c....most are 72c to 78c....although I havent pushed the benchmarks hard as I want to wait until this chip is under proper cooling (Custom Loop).....
Timespy: 18.613K
MARK 11: 40.185K
Old December 16, 2018, 07:07 PM
Good to know. Just waiting on some parts to build a 9900k with the h60
Mah Rig now
Mah Rig before
My stuff for sale.
Old December 16, 2018, 09:46 PM
rjbarker's Avatar
Good stuff...tomorrow Procyon II starts getting ripped apart...clean Rads...hey would anyone here say rinse with CLR concentrate...rinse with hot water...final rinse with distilled water..then let drain n dry for a day....(its what I did last year)....good enough for rads.....
I have a new CPU block coming and will take apart the EK GPU Blocks and clean them good...think there maybe gunk in one of em as the card suddenly started running up to 10c warmer than the other card... -
Cinebench @ 5.1 Ghz yields between 2115 cb - 2160 cb ....once in my case I'll run a few Stress Tests and see both what the vCore is I need for stable 5.1 Ghz and go up (hopefully from there)....I'll cap the vCore at 1.4125v - 1.4315v under load......fingers crossed I have a decent chip...
Timespy: 18.613K
MARK 11: 40.185K
Old December 18, 2018, 09:02 PM
I might do a clr watered down and let it soak in the inside a few times for 5 minutes or so at a time? Maybe longer? I fixed a bunch of sticking shower diverters and it worked perfectly no damage. They are chrome coated brass and copper.
I will be doing a cinebench as well. Whats the going recommendation currently for burning in cpus and video cards? I haven't had to do one in years.
Mah Rig now
Mah Rig before
My stuff for sale.
Old December 19, 2018, 09:57 AM
rjbarker's Avatar
I did diluted CLR in the rads...fill them up and rinses them for a few minutes....did this twice....then rinsed them really good with hot water (several times)...not sure about breaking in the CPU....I just "went for it"....I know initially with that crap Noctua air cooler I was hitting over 90c on the cores and had a couple throttle down.....that when I decided to get the H60.....
Timespy: 18.613K
MARK 11: 40.185K
GTX 570 SLI - Going Single Mayoo Video Cards 11 June 18, 2013 09:11 AM
gtx 680 single or sli? judo Video Cards 6 June 16, 2012 04:40 AM
[WTB] a good router flashed to good firmware gingerbee Buy/Sell & Trade 9 February 15, 2012 06:15 AM
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
what is a good Media player for a good price or any suggestions Shadowmeph HTPC Systems & Software 4 December 19, 2009 11:27 PM
