Old December 6, 2018, 07:45 PM
rjbarker's Avatar
Default Which Inlet / Outlet Ports on Darkside D5 BARREL 220 Reservoir
Hi Guys...just got this Dark Side Barrel 220 Pump / Combo Res...from Daz...no instrucrtion sheet to indicate which ports can be used for inlet / outlet....I want to use the 2 ports on the bottom...one in and one out.....but not sure which is which.....
Any ideas or experience or info please......
there are 2 ports lower and 1 port on top (also a fill port up top)...
https://www.dazmode.com/store/shop/w...l-medium-rev2/
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old December 6, 2018, 08:15 PM
JD JD is offline
Hmm if you look through them with a flashlight, you should be able to tell? The one that's dark and doesn't shine up into the reservoir would likely be the pump outlet.
Old December 6, 2018, 08:20 PM
sswilson's Avatar
It looks like there are extending tubes from at least one of the top tubes? Are those interchangeable?
Pretty sure the res's I've used have had a tube on the inlet/return which I assume is designed to direct the turbulent return fluid flow away from the output to the pump.
edit:
Or you could just go with JD's advice..... ;) (My experience has been the same when it came to bay reservoirs)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old December 6, 2018, 08:55 PM
rjbarker's Avatar
I'll have a quick look...surprised Daz doesnt include a simple instruction sheet...I hope I dont have to use the top port for inlet...buggers up the routing of my loop ;)
EDIT: So yes...when the Rez / Pump is held vertical (in the mounting position)...the lower port to the left cant see any light in the Rez when I shine my pen light in there (can see its just black acetol)....the port to the right I can see light shining into the centre of the Rez.....so can assume left side outlet port and right side inlet port...?......I'll throw a plug in the top port.
im coming from an XSPC Photon Rez / Pump combo and it was clearly marked in an instruction sheet which was in and which out.....
Timespy: 18.613K
MARK 11: 40.185K
Old December 6, 2018, 10:38 PM
JD JD is offline
I would say that's the correct assumption ;)
I think it's probably not a recommended configuration though since the pump will be drawing back in the water almost right away, likely causing some vortex action depending on your pump speed. Could introduce noise & air depending how it's setup.
Probably supposed to use it how it came with the plugs installed/pictured - left side outlet and top w/ tube as inlet. 2nd top plug would be for filling and right side plug would be for draining.
Old December 7, 2018, 01:12 AM
dustin1706's Avatar
Daz makes some good stuff, but he quite often doesn't list instruction manuals or full dimensions on the Dazmode or Darkside websites. Since you've got one on hand, would you mind telling me what the overall height for the entire 220 pump/res combo is? And the largest diameter? (looks like it's the pump cover)
On most (all?) centrifugal pumps, the inlet will be in the center of the pump and the outlet will be from the edges of the pump. If you look at the last photo of the clear pump top, you can see that the inlet "T's" into the central inlet for the reservoir.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old December 7, 2018, 10:44 AM
rjbarker's Avatar
From the top of the Rez to the bottom of the pump 8.5" and to the bottom of the upper pump piece 6.5".....yes like my older Photon (top port could be used as either filling and/or inlet and had 3 ports at the bottom ...1 for outlet and could use either of 2 for inlet).....I dont want to use the top Port as an inlet....doesnt work with my present loop routing..(I could but would rather not)....
Timespy: 18.613K
MARK 11: 40.185K
Old December 7, 2018, 01:21 PM
dustin1706's Avatar
Thanks for the dimensions!
Yeah, I just meant that you can see from that pic of the clear pump top which one is the horizontal inlet port as it ties directly into the vertical one.
Old December 8, 2018, 04:49 AM
KaptCrunch's Avatar
picture worth a 1000 words
pic say not use inlet port if rez tube installed on pump motor base (note 90 inlet is a no-no for pump inlet)
I suspect set-up will produce bubbles if D5 run at full speed (need to open inlet for max speed)
Old December 9, 2018, 08:39 PM
rjbarker's Avatar
Yes thanks Kapn Crunch.....I got the answer on Daz site as well...cheers...
Timespy: 18.613K
MARK 11: 40.185K
internal Reservoir or external Reservoir 7foot9 Water Cooling 7 March 31, 2012 08:27 PM
Tee connector before pump inlet Ichigo27 Water Cooling 4 January 12, 2012 07:01 AM
[FS] spyder paintball gun + 20inch Barrel kyle_L Buy/Sell & Trade 3 June 3, 2009 04:54 PM
Crysis 3000 barrel explosion Amon Gaming 12 December 20, 2007 05:28 AM
NCIX outlet store Jim Troubleshooting 5 July 6, 2007 09:43 AM
