Old December 5, 2018, 01:20 PM
rjbarker's Avatar
Default Terminal Block SLI - RIVE Migrate To MXIE
Hey guysQuick one..(thought this may come up)...just recieved the MXI E Board and I the first thing I checked was the top 2 SLI PCI E Slots....and the included HB SLI Bridge . The included SLI Bridge doesnt fit the present configuration on my 2 1080Ti 's presently mounted on my RIVE Board with FC Terminals to connect the Watercooling.....hhhmmmm.
It doesnt look like I can use my Terminal Blocks (which I like for mounting and rigidness)....its a Triple Terminal Block and Im using the top and bottom mounting positions...I have the middle blanked off....I maybe able to use the top and middle instead.
Any suggestions (most suitable) for connecting the 2 1080Ti's if I dont use the Terminal Block? Would like to be able to set-up both Cards together and simply lock them onto the Board then make Water Tube connections.....sorry I havent used anything other than the Terminal Blocks to connect 2 Cards....
Any suggestions welcome..
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old December 5, 2018, 05:16 PM
JD JD is offline
You could do small pieces of hard tubing, I think Bitspower used to sell it like that, 2 fittings and a short piece of acrylic tube. Nowadays you could just buy a 1M piece of tube and 4 fittings, cut to size and done.
https://www.dazmode.com/store/shop/w...-1012mm-black/
https://www.dazmode.com/store/shop/w...utside-canada/
Could do spacer fittings too, depending what the distance is. Combination of:
https://www.dazmode.com/store/shop/f...2Bmale-female/
https://www.dazmode.com/store/shop/f...s%2Bmale-male/
Old December 5, 2018, 07:17 PM
rjbarker's Avatar
Yeah thanks JD..did a bit more research and I believe I can get another Terminal Block with spaces that are designed for a Board with 2.4" SLi PCI-E spacing....my RIVE is 4 PCI-E Slots all 1.6" spacing....my present arrangement is 1st and 3rd slot so 3.2"......
Timespy: 18.613K
MARK 11: 40.185K
Old December 5, 2018, 08:28 PM
rjbarker's Avatar
Solved: This should do it...ordered direct from EK....wanted new Thermal Pads and some other goodies..so done ...say 2.4" and that as close it gets for my 2 PCI-E Slots.....thanks JD
https://www.ekwb.com/shop/ek-fc-term...-3-slot-acetal
Timespy: 18.613K
MARK 11: 40.185K
Old December 6, 2018, 09:22 AM
Cptn Vortex's Avatar
Dang, too late to see this. I have a spare of the block that would work for you from when I was running dual GTX 670's:
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.2GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
Old December 6, 2018, 10:45 AM
rjbarker's Avatar
^^^ Thanks anyhow Capn Vortex.....yes 2.4" is what I need (For Terminal Block)....well I now have spare Triple Terminal Block 1.6" spacing if anyone needs it :) ...Likely include it when I sell my RIVE Board and 3930K !!!
Timespy: 18.613K
MARK 11: 40.185K
[FS] X99 Deluxe/ Crucial Ballistix Elite DDR4 / 3930K / RIVE w FB block turtletrax Buy/Sell & Trade 15 September 14, 2015 11:10 AM
How to Clean HDD? How to migrate data quickly? geokilla Storage 3 May 1, 2013 07:27 PM
Koolance block now avail for RIVE X79 Eldonko Water Cooling 1 November 30, 2011 04:15 PM
Switches and Terminal Blocks sinticfury Troubleshooting 3 June 22, 2009 10:11 PM
