Old February 13, 2018, 07:37 AM
LegendMask's Avatar
Originally Posted by The Great Gazoo View Post
I have 800D and put my two bay EK rez in the lower two bays. I used a funnel with a long skinny neck to fill from the top port. Worked great - just pull the front face off of the case and you have more room.
Originally Posted by dustin1706 View Post
This. Depending on your exact reservoir, you likely won't be able to top fill if the res is in the uppermost bays. If you have it in bays 2/3 or below, no problem to fill it with the front panel off. If you absolutely want it in the top bays, you may be able to fill it with some difficulty if you temporarily remove the front I/O panel (2 screws). Reservoirs like the Koolance one I've been using have front fill ports as well which makes it easy.
I do have it already at the bottom, I guess WIP is about to be in session just trying to secure the parts and that damn GPU hoping to score a decent deal on it
Earth is Full, GO Home!!
eBay: kalsharabi - HeatWare: LegendMask - HWC: LegendMask
Old May 22, 2019, 02:18 PM
This is now i made my dual loop / pump / reservoir. It was really hard to fit but was working flawlessly !
https://imgur.com/du5CxzG
https://imgur.com/HfxzbNT
Old May 22, 2019, 02:59 PM
Run a tube from one of the top fill ports to the top of the case. Drill a hole and use a transition fitting or a fill port fitting then you don't need to move it around to fill it.
Quick snapshot of the midplate on my 800D leads below to soft tubing to the pumps using those fittings. Except that you would use a cap instead of another fitting and have that lead down into the res.
Examples
https://www.dazmode.com/store/shop/w...-black-nickel/
https://www.dazmode.com/store/shop/w...r-matte-black/
2700X Heatkiller, CH7 Hero, 1080ti Heatkiller, 32GB Ram, 2x500GB WD Black NVMe, Dual 1080 rads, dual D5S pumps.
Old May 27, 2019, 05:00 PM
I’d just go with a new resi. It’s such a big case with options.
Mah Rig now
Mah Rig before
My stuff for sale.
Old June 4, 2019, 12:56 AM
Originally Posted by clshades View Post
Id just go with a new resi. Its such a big case with options.
I agree with you. :)
Old June 4, 2019, 07:55 PM
The Great Gazoo's Avatar
I was a year ago. I am sure the OP has figured it out by now. lol
12mm vs 13mm Hard Tube Fittings bjcsoln Water Cooling 5 May 2, 2017 08:18 AM
[WTB] Hard Tube Fittings/cpu block/pump res (tube) zoinky Buy/Sell & Trade 0 April 18, 2017 05:41 AM
[WTB] 60mm acrylic tube (reservoir) CTA Buy/Sell & Trade 0 September 30, 2015 02:35 PM
