Old September 16, 2008, 03:18 PM
MpG's Avatar
MpG MpG is offline
Nice to hear! You never did say what pump you were using, but you may be surprised at how little a stronger pump helps cooling past a certain point. Sometimes, the heat dump from the stronger pump actually cancels out any gains from the increased flowrate. Point in case: There are more than a few D5/MCP655 owners who have found that turning their pump down actually improves temps by a degree or two, thanks to less heat being added to the loop.
Old September 16, 2008, 06:24 PM
Supergrover's Avatar
I notice a 2c difference with my mcp655 @ 1.5-2 verses max which is 5.
R.I.P.
Old September 17, 2008, 05:38 AM
ebdoradz's Avatar
thats means you have better temp with pump at 5 or with pump at 2
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
