Old February 26, 2019, 10:58 AM
Default Gpu Mini 4 Pin Fan header
Do you guys think the 4 pin mini header on my msi gaming x 1080ti can supply a 120mm corsair h55 fan and a 92mm kraken g12 fan? I cant find any info anywhere. The fan replacements seems to have 2 fans connected on a splitter wire but there are two 4 pin and one 3 pin. Im guessing the other two headers are for the leds. I bought a mini 4 pin PWM to 2 regular PWM but I just want to make sure the header is supplying enough juice. If not Ill have to get a molex and tach wire adapter.
Old February 26, 2019, 01:52 PM
SugarJ's Avatar
The supplied cooler on that card runs 2 fans off that same header, doesn't it?
Old February 26, 2019, 02:03 PM
Im not sure. I can't find any info about it and i can't tell by looking either well short of taking the shroud apart. But when i search for fan replacements they almost all show 2 fans hooked up to one wire.
Old February 27, 2019, 12:20 PM
...I called MSI at lunch today. I asked a tech about the header, he put me on hold for 30 min then i hung up...
Old March 3, 2019, 06:21 AM
MARSTG's Avatar
No, it doesn't ! Those are 2 additional 4pin pwm headers for 2 extra fans that can be controlled through the card's app, in your case the msi gaming app. Strix cards have that feature too.
Old March 3, 2019, 08:02 AM
Yeah it does, I finally found some pics of the frozr taken apart. You can see that both fans feed into the same 4pin header.
https://cdn.videocardz.com/1/2017/04...G-X-shroud.jpg
The other 4 pin is for the controllable led and the 2 pin is for the non controllable led.
Now just to find out how much that header can handle.
Old March 3, 2019, 08:30 AM
MARSTG's Avatar
Ah, on the Strix things are different
Old March 3, 2019, 08:44 AM
KaptCrunch's Avatar
since no info of MSI TORX 2.0 Fans spec's
need to use a clamp meter/multimeter that can measure milliamps on fan circuit
also if go over the current rating of fan controller will burn it out
Note: need to match fan draw for the fan software will throw a error if not matched, not boot or warming/alarm will sound
Old March 3, 2019, 08:48 AM
KaptCrunch's Avatar
can you screen shoot that forgetting this error 1011
The owner of this website (cdn.videocardz.com) does not allow hotlinking to that resource (/1/2017/04/MSI-GeForce-GTX-1080-TI-GAMING-X-shroud.jpg).
get out the microscope and read all IC's on card or read any info rear of fan (spec's)
youtube
fan mod
Old March 3, 2019, 11:58 AM
So are you saying even if I go below the spec fan draw I will most likely get an error? Im thinking I should just get another molex powered splitter and just grab the pwm and tacho signal from the gpu.
3 fan into one header Fan control? LegendMask Air Cooling 3 March 24, 2013 02:34 PM
HAF-X USB 3.0 Header Mayoo Cases 14 April 26, 2012 08:15 AM
Mix 3 pin Fan with 4 pin PWM fan and header Eluder Air Cooling 2 February 1, 2011 06:43 PM
ZOTAC Revolutionizes ION With Intel CULV-Powered Mini-PC and Mini-ITX Platforms FiXT Press Releases & Tech News 5 August 27, 2010 01:48 PM
Lian Li Launches PC-Q08A/B/R Mini Tower Chassis for Mini-ITX and Mini-DTX FiXT Press Releases & Tech News 1 April 29, 2010 09:17 PM
