Old December 3, 2017, 12:00 AM
sf101's Avatar
Default First time in a very long time on 290x's and 7970's OC working fine with 3rd party OC
I will say i have had some serious issues with AMD drivers for the last probably 2 years and overclocks not working.
Mainly When any overclock or adjustment was changed the cards would lock into 150mhz core 350mhz mem until i actually uninstalled the driver and reinstalled them.
was happening in single or crossfire.
2 entirely different systems one with a dual 290x config one with a dual 7970 HD config both with or without crossfire i could not overclock.
I posted these issues here and overclockers.com almost 2 full years ago now and had many others seeing the same exact thing with same cards.
A week or two ago i rebuilt the guest pc which has 2x 7970 hds in Crossfire and figured heck ill try to OC them with Afterburner.. and amazingly it worked great set the speeds to what i used to have them run at and aggressive at that.
Working fine no issues with this mhz reset or mhz stuck at 150/350
Tonight I decided to try on my main pc also .. no issues yet on afterburner with newest drivers and newest afterburner .
2X 290X's @ 1235 core atm , MV on core upped and 50% load voltage upped. usually any change was enough for it to freak out and default too 150/350 i went through that literally like 100x before giving up , i was truly hesitant to try it but i saw a ray of hope in that 7970 system so i tried and .. no issues ..
Thank god AMD fixed this it was driving me nuts, knowing my water looped cards could run far faster but also couldn't after some mysterious driver issue related to their "global wattman" introduction in drivers.
This made me loose alot of faith in my AMD GPU's. i will burn their HQ down if it happens next driver tho.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old December 6, 2017, 01:49 PM
MARSTG's Avatar
Yes, I think it was just a driver problem. Had the same issue with the mining driver.
Old December 9, 2017, 09:03 PM
sf101's Avatar
Yea i just mostly made this post because there are probably a-lot of people who dont realise its fixed and had given up like i did.
These cards 290x's are still pretty solid in most everything even my 7970's on the guest pc do well still ..
When oc'ed well they gain a few years more life obviously for those like me that have been holding off upgrading.
Looking at the recent pricing of new cards ill drag out a upgrade as long as possible myself getting 1150 or 1200 out of 290x's gives you an almost
30% core increase from stock and for those with 2 in crossfire like me crossfired cards can hold their own still in engines that support it .
I7-6700T-Work
3770K@ 4.8GHz -Main
3570K @ 4.5 -HTPC
SF101 HW BOT
It's Been a Long Time Overclocking.ca Off Topic 13 April 16, 2012 09:35 AM
First time watching TV in a long time jibz Off Topic 12 January 23, 2012 12:42 PM
Shipping Time: how long??? jcmaz Off Topic 10 July 30, 2009 02:03 PM
New build in a long time!!! Delavan New Builds 7 April 10, 2009 07:09 AM
Lan Party Time!!! SHaCK Canadian LAN Parties & Events 10 May 15, 2007 06:36 PM
