Old January 10, 2019, 02:01 PM
Originally Posted by AkG View Post
Unless it is a killer deal I would probably not go used for hdds. Def not without seeing a smart reporting showing power on hour count, and smart reallocation count (ie bad sectors that have been remapped), etc etc.
My bad! I actually meant used enterprise/data centre SSD drives. I seem to recall that someone here use to buy Intel ones.
Old January 10, 2019, 08:23 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Gotcha. Will really depend on the model of the drive... and what it was used for. I would not buy a MLC enterprise drive unless I had proof of life left (gb of writes.. and over how long a period of time). Even then IDK... depends on the model and price. IE they are usually loaded with a ton of over-provisioning and are not the fastest (usually), instead their job is to be durable.. but that durability has a limit. Sooo be careful.
Old January 13, 2019, 03:52 PM
Dark Knight's Avatar
If Consumer grade MLC drives such as the 840/850 Pro can write a Petabyte or more before running into degradation and issues I'd say an enterprise MLC drive would do the same.
New upgrades. Shadowarez New Builds 0 August 20, 2017 10:11 PM
Upgrades FrostbittinHD Video Cards 12 March 29, 2012 09:40 PM
PC upgrades bassplayerdave New Builds 0 October 15, 2010 11:42 AM
