Old January 6, 2014, 05:00 PM
sakage.shinga's Avatar
Default Question about my Crucial M500 480GB
Hi guys,
I'm installing a Crucial M500 480GB SSD on my new rig, and I'm wondering if I should partition it. I figure that OS + Apps will take up about 80GB, max 100GB, that leaves me 380-400GB for game installations. I also have a Caviar Black 2TB HDD that will load games that don't benefit from SSD speeds. My question is whether I should partition my SSD (e.g. 80GB for OS, 400GB for games on a separate partition) and use the larger partition as cache for my HDD, or simply leave the SSD untouched.
Scenario 1) SSD holds OS + Apps + Games, unpartitioned. HDD holds rest of games.
Scenario 2) SSD holds OS + Apps on 1 partition, Games on separate partition. HDD holds rest of games
Scenario 3) SSD holds OS + Apps on 1 partition, 2nd partition used as smart cache for HDD. HDD holds all games, but is now a "hybrid" drive?
Thanks for any input!!!
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old January 6, 2014, 06:21 PM
200 gigs min for an OS imo... doesn't take long to fill it up with software. Rest for games.
Mah Rig now
Mah Rig before
My stuff for sale.
Old January 6, 2014, 06:48 PM
SugarJ's Avatar
Scenario 1 is simplest. I'm not sure you can use only part of a SSD as a cache drive.
Old January 6, 2014, 06:52 PM
really? I didn't know you couldn't partition an ssd?
Mah Rig now
Mah Rig before
My stuff for sale.
Old January 6, 2014, 09:19 PM
Honestly whats the point to partioning a SSD even if you could? It literally makes no difference in the end.
Old January 6, 2014, 09:33 PM
SugarJ's Avatar
You can partition it to your heart's desire. I'm not sure it's possible to use a secondary partition as a cache drive for your HDD while using the primary partition as an OS.
Old January 7, 2014, 10:41 AM
Dzzope's Avatar
I wouldn't bother TBH.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old January 7, 2014, 11:43 PM
Here's another question. I'm having second thoughts about the Crucial M500. Would the Samsung 840 Evo 500GB be a better choice in terms of reliability? I know it is noticeably faster than the M500, but honestly I don't really care about that so long as the Crucial isn't dead slow. I care much more about longevity and reliability - which SSD wins? If both are the same, then i might just change over to the Samsung since it can be had for a few dollars less yet is faster.
Old January 8, 2014, 06:41 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Short answer....nope.
Longer answer....hell NO.
The EVO uses TLC NAND. Sure Sammy are claiming its second gen TLC but, IMNSHO tri-level (ie SIX states) is not ready for prime-time and Sammy once again are using peeps as guinea pigs. Give it 2-3 more years before even looking at TLC. Stick with the Crucial.
Old January 8, 2014, 08:32 AM
Haha OK, sticking with the Crucial. Thanks!!!
960GB Crucial M500 available now on newegg Spblue Storage 2 June 10, 2013 06:44 AM
Crucial M500 480GB SSD Review Comment Thread SKYMTL Storage 8 June 6, 2013 12:50 PM
Plextor M5 Pro Extreme or Crucial M500 brewer265@ Storage 7 May 24, 2013 07:26 AM
Micron / Crucial Launch New M500 SSDs, 960GB for under $600 SKYMTL Storage 1 January 10, 2013 07:32 PM
