-   Storage (https://www.hardwarecanucks.com/forum/storage/)
-   -   delete master boot registry ? (SOLVED) (https://www.hardwarecanucks.com/forum/storage/64911-delete-master-boot-registry-solved.html)
Jim January 4, 2014 11:16 PM
need to remove and add master boot registry (hard drive obviously) due to rootkit infection,prevents antivirus from updating or scanning,ran a malware removal tool 1 infection "fixed" AV still no go,is there a way to do this from within win7 as drive is installed as a secondary?
drive was given to me,ether way I want to wipe it completely for security reasons
googled first,not getting down the right path,not much in the forum
thanks
used this https://partedmagic.com/
Perineum January 4, 2014 11:35 PM
have you tried TDSS Killer from Kaspersky?
KaptCrunch January 4, 2014 11:37 PM
yes if the computer has AV on it and up to date, just install it as a secondary and scan the whole drive
wanting data ? or just format the drive if no data needed
ZZLEE January 5, 2014 12:18 AM
If you don't need anything on the drive.
Format LINUX on the drive
Update Drivers from drive web site.
Format to windows
should be good
Edit: IF you have a marvel stata 6 controller PM me ( not fore open forums but works like a charm )
Whats the drive we are working on?
Jim January 5, 2014 12:53 PM
Format to windows
should be good
https://partedmagic.com/used this from a thumb drive,it's a complete distro with great disk tools,got me what I wanted,however using the Gparted tool I couldn't figure out how consolidate the two partitions into one,working on that still just to learn something new.And it has easy one click MBR removal which is nice.
Jim January 6, 2014 07:18 AM
good product thanks
Jim January 6, 2014 07:28 AM
thanks Kapt
Chris January 6, 2014 08:38 AM
I use gparted all the time (my main os is debian). To consolidate 2 partitions, you have to delete one and expand the one the is left. The expansion will take a few minutes, but it will work. I have used it on win8 to change 2 partition to 1 single partition.
Jim January 6, 2014 11:16 AM
um yea works just as advertised,more of a dumb operator problem than anything,how ever still shows an unallocated space approx 5% less than the total size of the drive,hmm...
