Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old May 28, 2019, 09:56 AM
Mr. Friendly's Avatar
Default Guru3D review of new Noctua NH-U12S cooler
https://www.guru3d.com/articles-page...-review,1.html
beats the 12A and is 1 degree from matching the D15!
Old May 28, 2019, 12:35 PM
Sorry, but their colour scheme is horrendous.
Old May 28, 2019, 12:57 PM
I hate windowed cases, so don't care. and in the end, it should be about performance...factor over form, not the other way. vanity means inadequacy.
Old May 28, 2019, 01:03 PM
Can deal with their colors.. but their price tag.. not a chance. I'd rather invest into AIO than this.
Old May 28, 2019, 01:06 PM
I have more than a few Noctua fans on my cooling unit, as ugly as they are they still work really well.
Edit: About their price tag... yes costly but even far from the most expensive fans. I think i bought my collection of them at about $15-$20 each and some fan now are $40+ each with flashy RGB coloring. But previously I was buying coolermaster fans and a pile of other brands and they were all failing. Some the motors would just die, others the plastic stretched and the blades started rubbing against the frames so instead of replacing a random dead fan every 6-8 months I have been running them for numerous years without a single fault yet. The cost of constantly replacing cheap fans was getting to be a pain, especially the effort to get them out of my setup.
2700X Heatkiller, CH7 Hero, 1080ti Heatkiller, 32GB Ram, 2x500GB WD Black NVMe, Dual 1080 rads, dual D5S pumps.
Old May 28, 2019, 01:19 PM
Bond007's Avatar
If you donít want a noisy pc, quality air coolers are still better than AOI....from every review I have seen. Not peak performance with high rpm fans, but if you pick a reasonable to quiet dB level, air coolers will have better temps.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old May 28, 2019, 01:20 PM
A product designed to fail... one day.
Old May 28, 2019, 01:24 PM
So does any cooler... fans have a bearing life and can fail at any minute. AIO have at least a 5-6 year life span.
Old May 28, 2019, 02:02 PM
not necessarily true. we had a customer with ThreadRippers and their AiO's constantly died. I suspect they wore out the pumps due to the higher temperatures they ran.
and you can't replace a burnt out pump on an AiO kit. a fan on a HSF is a simple fix.
Old May 28, 2019, 02:09 PM
That's not an argument for AIOs. They use fans on their radiators to remove heat just as heatsinks do. How that heat travels is what causes an additional point of failure for an AIO, and that's what Prickly007 is getting at.
Heatsinks have wicking material inside the pipes to transfer heat to the fin stack - this should work virtually indefinitely. Pumps are a mechanical device with a stated MTBF that is exponentially lower than the former.
Besides that, you also have to consider how confident you are in how sealed your AIO really is, otherwise expect evaporation, regardless of the formulation of fluid they are using.
Noctua NH-U12S Query user604 Air Cooling 1 March 3, 2014 08:51 PM
Noctua NH-U12S vs Corsiar H80i? draemn Air Cooling 5 October 20, 2013 03:10 PM
Noctua NH-U14S & NH-U12S Review Comment Thread SKYMTL Air Cooling 10 June 17, 2013 07:04 AM
