Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old June 27, 2019, 06:32 AM
Mr. Friendly's Avatar
Default VESA talks DisplayPort 2.0
https://www.guru3d.com/news-story/ve...esh-rates.html
3x the bandwidth of 1.4a and fully backwards compatible. no word on release date though...
Old June 27, 2019, 09:28 AM
Entz's Avatar
This is great in that you will be able to drive 4K 144hz + without issue or maybe some wide variant of it.
Also interesting that its using the TB3 Phy... Maybe this is why Intel decided to release it as open/royalty free for USB4 (or vice versa). Its going to be so ubiquitous . Lets hope they fix Intels self imposed issues with it (forced BW reservation) ;)
My fear is just how long it is going to take for things like this to end up on cards.
Old June 27, 2019, 09:38 AM
Entz's Avatar
I take some of that back, after reading Anandtech. Tethered connections are stupid and this is a non-starter for most.
Old June 27, 2019, 10:14 AM
how come? for multi-monitor display setups, it has a undeniable level of convenience.
Old June 27, 2019, 10:32 AM
Entz's Avatar
Having a non-replaceable manufacture determined fixed length cord for every device limits the ability to use different lengths to fit your needs as well if something breaks or a cable/connector goes bad throwing out a 700$ monitor is CRAZY
Old June 27, 2019, 10:39 AM
Honestly at this point I'm all for them killing off HDMI & DisplayPort for USB-C to handle video. 4 USB-C connectors could almost fit in the space of 1 regular sized display port connection, less space taken allows for better venting on an air cooled card. Daisy chaining USB-C monitors is a huge convenience on multi monitor setups etc.
2700X Heatkiller, CH7 Hero, 1080ti Heatkiller, 32GB Ram, 2x500GB WD Black NVMe, Dual 1080 rads, dual D5S pumps.
Old June 27, 2019, 10:48 AM
oooh, you meant tethered as in wired directly in. agreed, that's a terrible idea.
Old June 27, 2019, 01:45 PM
Displayport 1.4 is ~32Gbps*
Displayport 2.0 is ~80Gbps*
HDMI 2.1 is ~48 Gbps*
USB 3.2 Gen 2x2 is ~20Gbps*
Thunderbolt 3 is ~40Gbps*
USB 4 is ~40Gbps*
*Effective rates are lower
2560x1440 @ 120hz @ 8 bit = 13.27Gbps
3840x2160 @ 120hz @ 8 bit = 35.64 Gbps
3840x2160 @ 120hz @ 10bit = 44.55 Gbps
Keep in mind 10-bit is required for true HDR. As such, it's not feasible to completely replace DP or HDMI for GPUs.
Regarding packaging size - apparently Type-C connectors don't stack particularly well, as evidenced by the lack of them on motherboards, generally with that cited as the reason why. It'll be a problem on GPUs as well.
Old June 27, 2019, 02:33 PM
You make a good point about 120hz required throughput and wasn't something I was thinking of was thinking more form factor than anything.
USB-C doesn't need to be vertically stacked though for a GPU...
Radeon 6990 for reference... https://img.hexus.net/v2/TekSpek/AMD...radeon6900.jpg
4 mini display ports and a DVI didn't need any vertical stacking, and 4 USB-C connections would be even smaller than the 4 mini display ports.
Old June 27, 2019, 06:09 PM
Yes but you originally indicated 4x Type-C fitting in the space of 1x Displayport, but that could only be possible with stacking, something that isn't currently being done. It's likely 4x Type-C would allow for a 5th connector, similar to the 4x DP/1x DVI of the 6990.
This is of course assuming a reference size PCB, and not the egregious tall or "wide" cards that have come out in recent years.
NVIDIA officially supporting VESA adaptive sync as of 15 Jan 2019 Lysrin Press Releases & Tech News 37 January 20, 2019 02:33 PM
VESA Wall Mounts Fleurious Display Units 8 September 25, 2018 10:12 AM
Help finding a TV mount for VESA 600mm x 300mm justmehereajax HTPC Systems & Software 7 March 27, 2017 09:27 PM
Where to buy replacement VESA screws Caldezar Guides & How-to's 5 February 6, 2017 03:51 PM
I Need a Vesa 100x200mm to 100x100mm adaptor CoolHandL Display Units 1 October 29, 2010 12:32 PM
