Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old June 19, 2019, 11:09 AM
Mr. Friendly's Avatar
Default AMD's Rome Based Epyc Line Up Leaked
https://www.tomshardware.com/news/am...ked,39681.html
some nice CPU's in there and the TDP's appear very reasonable.
Old June 19, 2019, 11:58 AM
Bond007's Avatar
Interesting. I would have expected this to start with 12 or 16 cores. The market will let AMD know if they need to keep lower core count CPUs in the EPYC lineup.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old June 19, 2019, 12:24 PM
the lower core count will be for entry level servers. if positioned properly by price, it will put a hurt on Intel as their entry level W Xeon's are only 4 and 6 core. you can get some 8 core Xeon Bronze's, but they have pitiful clock speeds, so again, could prove beneficial for AMD.
Old June 19, 2019, 01:10 PM
Entz's Avatar
I am sure it also has to do with die quality. It seems like 8 is the "max" per chiplet, so a poor quality one that needs lots of power to clock higher could be the entry level.
Though for entry level servers, if you don't need obscene amounts of RAM, I am expecting Supermicro/Tyan/etc to have TR or even AM4 based boards. That 3950X would absolutely demolish intels E3 Xeons (or whatever they are calling them these days) for single processor boards.
Old June 19, 2019, 02:09 PM
Intel has a very fragmented eco-system for entry level Xeon stuff. There is an E series, which replaced the E3...and a W series, that's targeted at workstations, but is being used for some entry level servers. both are 4 core or 6 core parts only. then you go into the Bronze, Silver, Gold & Platinum garbage :P
AMD 'Rome' Getting DDR4 3200mhz RAM Mr. Friendly Rumor Mill 2 April 12, 2019 07:59 AM
AMD Talks 7nm - Epyc, Zen 2 & 3 as well as GPU Mr. Friendly Press Releases & Tech News 5 November 7, 2018 08:46 AM
7nm Zen 2 will be launched as Epyc server CPU first! Mr. Friendly Press Releases & Tech News 0 July 27, 2018 01:22 PM
Rome 2, another game with no sli or crossfire support LionRed Gaming 32 December 2, 2013 06:00 AM
Atheros based wlan card vs intel based. supaflyx3 Peripherals 3 July 23, 2010 03:24 PM
