Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old December 6, 2018, 04:38 PM
Mr. Friendly's Avatar
Default details leak for Mobile RTX 2070 and 2080 Ti
https://www.tomshardware.com/news/rt...-ti,38206.html
RTX 2080 Ti has 68 compute units & 11GB of RAM, type not specified, with the GPU @ 1.54Ghz.
RTX 2070 Max-Q has 36 compute units & 8GB of memory, type also not specified, with the GPU @ 1.3Ghz.
interesting that they're being paired with Coffee Lake and not Coffee Lake S CPU's though...
Old December 7, 2018, 11:04 AM
Soultribunal's Avatar
I very much hope these will still be mostly fully enabled GPU's and we don't go back to M variations at all.
Time will tell I guess.
-ST
www.realhardwarereviews.com
Old December 7, 2018, 11:57 AM
Caldezar's Avatar
As always with laptop GPUs, thermals and the noise of a cooling solution is a huge factor. It doesn't matter how powerful a laptop is... if it sounds like a wind tunnel, then I'm not interested in using it.
Old December 7, 2018, 12:03 PM
The 1080 OC that my Laptop has is right now the limit of its cooling potential (unless Dell decides to make a thicker laptop for a 2080 / TI).
I don't think anything with a 1070 and beyond doesn't sound like a wind tunnel unfortunately.
There are 5 of us who use Gaming Laptops in my Work LAN Group, and when they all spool up its pretty spectacular in terms of noise, its like a symphony almost with the way each fan has it's own pitch.
I solve this by putting on my Sennheiser's and then all I hear is the game.
-ST
Old December 7, 2018, 12:11 PM
Caldezar's Avatar
-ST
Yeah, I hate that this is the norm. I understand the want for portable gaming options, but a headset to drown the noise doesn't work great if you're at home and need to hear when your wife calls you or a baby wakes up.
Old December 7, 2018, 12:35 PM
I agree.
I solved that by putting a highly modified Ambient Noise sensor (something we use at work for paging systems) with an 12V Strobe in the Man cave.
So if the Wife Hollers, or the Doorbell rings/Dogs bark, the light goes off and I drop the headphones.
But yeah, for everyone else without access to this kind of gear, it sucks.
-ST
Old December 7, 2018, 02:21 PM
when you game with a notebook, you use headphones...notebook speakers are terrible. so while fan noise is bothersome, when you are gaming it really is a non-issue cause you are using headphones.
of course it will always be the goal to create a quiet gaming notebook...but we're not there yet unless you're only doing 1080p, cause then you don't need a top end GPU. :P
Old December 7, 2018, 02:31 PM
Actually, that is not quite true anymore. At least on my AW 17 the speakers and mini woofer are quite powerful and clear. I can crank it right up without any 'tin, warble' sound. They've come a long way too.
Some of the entry level units for sure, but the high end units that I've seen, its quite amazing the quality.
-ST
NVIDIA RTX 2080 Ti, 2080 & 2070 Explained - Comment Thread SKYMTL Video Cards 69 September 14, 2018 07:11 PM
certification applications leaks GTX 2070 and 2080 existence Mr. Friendly Rumor Mill 2 August 2, 2018 10:39 AM
more Z390 and Core i9 details leak... Mr. Friendly Press Releases & Tech News 1 June 27, 2018 11:24 AM
Ryzen Plus details leak? Mr. Friendly CPU's and Motherboards 5 March 11, 2018 06:08 PM
