Old September 14, 2018, 03:09 PM
Mr. Friendly's Avatar
Default best charger for iPad's and iPhone's?
I've got an original iPad Pro 9.7 and a newer iPhone 8 Plus and need another charger. I've usually gone with Anker dual port chargers, but thought I'd inquire if others have found better solutions?
iPhone 8 Plus uses the better 5w for charging, but I think my older iPad is still limited to the 2.4w or whatever...takes forever to charge while the iPhone is done lickety-split.
also, I know the iPhone 8 and 8 Plus support wireless charging...but I'm not sure if my Otterbox Defender case would interfere with that. anyone know?
also, this is a power question, so under the power supply forum...but if mod's think this is better under the forum for mobile tech, feel free to move.
Old September 14, 2018, 03:17 PM
Original Apple charger. All other USB bricks from Anker and Aukey that I've tested have bad electrical whining. Even OG Samsung fast charger brick makes annoying noise.
heatware
Old September 14, 2018, 03:51 PM
Ive never had any issues but for one Anker refusing to stay in the socket.
Old September 14, 2018, 03:56 PM
Sagath's Avatar
Max charging rate <iP8 is 10w. (5v@2A). 5W chargers are 5v@1A.
>iP8 is 7.5w wirelessly, 18w wired (9v@2A). The case may or may not affect the wireless charge, as it is induction based and range does play a factor.
A charger is a charger is a charger, assuming you're buying a reputable brand and not low quality garbage. Chargers will always downgrade to the max wattage a device will take, or rather a device will only take the max draw it can handle from a charger.
Old September 18, 2018, 12:07 PM
this is a truth! watts/amperage are pulled/consumed, only voltage is delivered/forced! :)
also, does anyone know if a thick case would interfere with wireless charging? my iPhone 8 Plus is in an Otterbox Defender.
Old December 7, 2018, 10:52 PM
Trial Member
Anker Powerline+ II This is the best chager I have ever used..You also try this for good result
Hardware and Networking
Old December 14, 2018, 09:34 AM
My iphone x comes with a normal cube that is rated at 5V 1A, same as any other iphones. But, my 10.5 ipad pro comes with a 12 W (5.2V 2.4A) charger. It charges my ipad fast, and also my iphone x very fast. I also have a wireless charger from Ikea. It took more than 2 hours to charge iphone X from 15% to 100%.
I would advice to buy a 12 W charger from Apple.
Old December 14, 2018, 12:47 PM
dustin1706's Avatar
I've been using the Aukey 2.4A chargers as I travel a lot and they are quite compact. Never noted any noise or had any issues with them.
https://www.amazon.ca/Aukey-12W-2-Po...=aukey+charger
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old December 14, 2018, 07:42 PM
If you read the spec carefully, it is 2.4A, but split between 2 output, each having 1.2A.
There are some that have 2A and 1A chargers, but need to look at the specs.
New iPad (2017), Refurbished iPad Mini/Air 2, or Android Tablet? geokilla Mobile Computing 2 April 30, 2017 08:08 PM
iphone/iPad app to this forum elec999 iPhone & iPods 1 November 7, 2013 11:32 AM
[FS] iPAD 3G, iPhone 4...Price drop... kazman Buy/Sell & Trade 1 November 10, 2012 05:05 PM
Iphone/Ipad = Locator ( The Register.com) ZZLEE Reviews & Articles from the Web 5 April 22, 2011 07:22 PM
ROG Connect on iphone and ipad now available! jay51 iPhone & iPods 5 September 24, 2010 05:51 PM
