-   Power Supplies (https://www.hardwarecanucks.com/forum/power-supplies/)
-   -   BFG ES-800 800W PSU Review Comment Thread (https://www.hardwarecanucks.com/forum/power-supplies/4793-bfg-es-800-800w-psu-review-comment-thread.html)
Oklahoma Wolf February 27, 2008 09:09 PM
Originally Posted by arminkropp (Post 43018)
The use of the word "chink".
Not a real problem IMO - it's pretty clear from the context of the paragraph he's not talking about any derogatory use of the word.
jonnyGURU February 27, 2008 10:09 PM
Right. "Chink in the armor" is a very old and very common phrase, for example. Chink, in most cases, means what SKYMTL meat it to mean in his context than a derogatory term.
Babrbarossa February 28, 2008 05:01 AM
[H] reviewed this PSU as well and found some wackiness with the output from the 3.3V rail (although not outside of atx12v specs) - I'll be interested in seeing the graph when it's posted
SKYMTL February 28, 2008 06:11 AM
The revised graph is posted. The fact of the matter is that any modern computer will not even put a 25% load on the +3.3V rail....
jonnyGURU February 28, 2008 06:49 AM
Just the RAM, right? I can't think of anything else and these days some motherboards regulate RAM voltage off the +5V rail. Even the +3.3V on a SATA lead isn't used by the drives. :(
SKYMTL February 28, 2008 07:14 AM
Yes...it is only the ram from what I know. Now, with the inception of DDR3 (and to a lesser extent, DDR2) there is some pretty significant savings in the amount of power being used by the ram. While we still NEED the +3.3V and +5V rails, they are never loaded anywhere near their maximum outputs...
Oklahoma Wolf February 28, 2008 01:17 PM
That's a side effect from the design used. It pulls the whole 3.3V/5V output off the already regulated 12V output, and there just isn't enough room in the supply to really filter those two outputs very well.
Not a big deal though - as long as it's in spec, it's not worth complaining about since the demand for those two rails these days is a mere shadow of what it used to be.
