  #21 (permalink)
Old November 24, 2009, 09:28 PM
Draex's Avatar
Well I got an electrician in today and what we ended up deciding was just to pull some new wires (12-3 I think he said) from the breaker panel and put in two new 2 20AMP Breakers (plenty of room in panel) on a split receptacle. It turns out the baseboard heater wiring first goes to a thermostat before the baseboard heater as well. We also discovered that one of two existing 15AMP Breakers in that room is also tied to some receptacles in another room.
  #22 (permalink)
Old November 24, 2009, 09:52 PM
Originally Posted by MarkOne View Post
I'm not sure the lack of grammar have nothing to do with you understanding
Actually, that's exactly why I'm having trouble understanding you. I'm sorry for putting it so crudely, but that's just the way it is.
  #23 (permalink)
Old November 25, 2009, 05:31 AM
MarkOne's Avatar
I have 0 problem with that... today I sell a DRDRW to a spanish woman, I have to use an online translator to understand her. When you want to understand you always find a way
Originally Posted by Zero82z View Post
..... I'm sorry for putting it so crudely, but that's just the way it is.
  #24 (permalink)
Old November 25, 2009, 03:10 PM
Perineum's Avatar
Now you're laughing.....
  #25 (permalink)
Old November 25, 2009, 03:53 PM
Draex's Avatar
Not at the quote :(
  #26 (permalink)
Old November 25, 2009, 07:18 PM
JD JD is offline
Not at the quote :(
lol get a couple more then? Not like you have to go with the first guy...
As long as they're ESA certified you should be fine.
  #27 (permalink)
Old November 25, 2009, 08:04 PM
Draex's Avatar
The quote I received was just over $600 ($50/hr + materials) approximately 80ft run, the quote includes getting a drywaller into repair the sections of drywall he needs to cut out to run the wire. As far as other quotes, everyone else I contacted in the phonebook was much higher then $50/hr
  #28 (permalink)
Old November 26, 2009, 01:21 PM
JD JD is offline
Well depending how handy you are, you could probably patch the drywall yourself and save some money.
Phenom II 965 C3 - Availability? CMetaphor CPU's and Motherboards 1 November 10, 2009 02:06 PM
OCZ Technology Announces the Immediate Availability of Z-Series Gold Power Supplies Gav Press Releases & Tech News 5 July 31, 2009 12:04 PM
GTX 280 Power-up Issues sw3pt Troubleshooting 21 January 10, 2009 07:46 AM
FM-123 availability silverchair Water Cooling 1 January 27, 2008 12:11 PM
