Old February 3, 2019, 01:35 PM
Default No heatsinks on motherboard Z77 OC 2600K
I have this lowend Z77 board https://www.gigabyte.com/Motherboard...-D3H-rev-10#ov
It does not have heatsinks on the VRM, etc.
Should I bother with a OC on a 2600K?
Should I install thermal tape and attach small heatsinks I get on Ebay and install a TOP down cooler to help VRMs? Whats a good top down cooler? Cheap alright one.
Fun project. I don't really OC but I would like to OC to about 4.2GHz and hope it lasts a while.
Gone mobile and back to Gaming to LEARN! :p
Laptop: Dell G5 i5-8300H, 16GB, 1050 4GB, Samsung EVO 970 500GB+EVO 860 500GB, Microsoft Sculpt Comfort Mouse
Gaming PC: i7-2600K, 32GB, EVGA 1070 8GB, Crucial BX500 250GB, WD 4TB, ASUS Xonar DX playing just CS:GO and some StarCraft 2
HTPC/Server: See "My System Specs". I also use it to virtualize an instance of Windows to my mobile devices.
Graphics Designer and Tech Journalist @ www.RealHardwareReviews.com ID: eyetrance
Old February 4, 2019, 01:54 AM
https://www.ebay.ca/itm/20pcs-Alumin...D8Jn:rk:1:pf:0
This is what I am getting to help cool the mobo. I will add a fan to cool the area.
I don't want to wait that long for them to arrive from China, especially during Lunar New Year. Does anyone have this size of heatsink along with thermal tape they could sell me?
Old February 4, 2019, 02:26 AM
In my experience with similar boards, as long as you give the VRM area good airflow you should be fine, especially if you only want to push into low 4's range.
Old February 4, 2019, 07:41 AM
Bond007's Avatar
IMO low 4s without high voltage (like an auto OC), and you should be fine. If you start running high OC or high voltages then you may be asking for issues.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old February 25, 2019, 09:03 PM
I bought heatsink from ebay
https://www.ebay.ca/itm/20pcs-Alumin...72.m2749.l2649
I wanted to buy better heatsinks but I dont think its really worth $30 for enzotech ones. I would rather find a better Z77 board for about double that lol
They have to be a special size = 6.5x6x3.5mm. I also measured them myself. I have 15 mosfets and this package gives me 20.
I have a top down cooler I bought a while back that I am gonna use (CM Gemini M4) that I think will help with the cooling too.
Old April 8, 2019, 08:15 AM
Got the heatsinks and installed them but it will be used as a backup mobo.
My buddy sold me a Asus PBZ68 Pro board with massive VRM heatsinks. My 212 evo had to be mounted bottom to top to fit lol because of the heatsinks.
But I still get throttling when I benchmark it. Ever 30 seconds the CPU usage drops to 80s% and goes back up to 100%. I use 7zip.
Old April 8, 2019, 01:08 PM
Bond007's Avatar
What temps and voltage do you have under load?
Old April 8, 2019, 06:24 PM
Max temp so far is 64 c
I will check volt
Old April 10, 2019, 04:29 PM
1.341V and 65 C
Old April 12, 2019, 05:35 AM
Any ideas? Or does this look right? Image above ...
EK H30 VS heatsinks? (NH-D14) Keep-six Overclocking, Tweaking and Benchmarking 6 September 15, 2011 08:27 PM
Heatsinks Zygote Cases 5 August 3, 2011 03:19 PM
CPU heatsinks? technix Overclocking, Tweaking and Benchmarking 30 March 28, 2010 09:31 AM
[FS] GPU and Heatsinks ddude27 Buy/Sell & Trade 8 June 21, 2009 09:56 PM
