Old August 22, 2018, 04:47 PM
Default 6 pin server fan connector
Hi, guys, can anyone tell what these 6 pin connectors are called and where may I bu 20-30 psc of them. Thanks
Old August 22, 2018, 04:59 PM
sswilson's Avatar
What's the PN on the fan? Maybe that would help.....
Old August 23, 2018, 12:50 AM
Default PN is VGMHR or 2X0NG
https://www.ebay.com/itm/Dell-PowerE....c100005.m1851
Old August 23, 2018, 03:19 AM
KaptCrunch's Avatar
MADE BY SUNON
looks if fan and a thermal connection are on that block connector
follow wires to fan 3 or 4 wire
can use a safety pin and remove connectors from gray block and put in a standard pc fan header plug
look at pin outs for fan headers to get correct wire placement as for thermal connection leave it
or use a diode checker to find polarity and if mother supports thermal monitoring
Tags
fan server motherboard
4 pin connector into a 6 pin? LaMig Power Supplies 12 April 6, 2012 03:43 AM
4+4 pin CPU connector vs 8 pin ATX connector sstrucel CPU's and Motherboards 1 August 5, 2011 07:45 AM
Which connector do I need? Fudd Rucker Water Cooling 13 January 25, 2011 09:18 AM
[WTB] Need a wc'ing sli connector G777 Buy/Sell & Trade 6 November 24, 2010 06:02 PM
8 Pin 12V ATX Connector element291 Power Supplies 6 August 24, 2009 08:52 PM
