Old August 12, 2018, 09:14 AM
Default FPS drop and high disk usage spike
My pc:
X470 strix
Ryzen R5 1600
16gb ram
Ati 7770 1gb
SSD 120gb - installed win10
Wd blue 1TB ezex - for games, programs
In Hellblade: Senua's Sacrifice i have fps drop and when I minimize and go to taskbar I got this:
when stutter happen when game is on HDD (disk 1):
When I installed it on SSD (disk 0) I got this:
I didn t reinstall windows when I got new mbo, could that be a problem? Clean windwos install?
First I thought that HDD is dying but if this happens also on SSD that I think that this is not a disk problem? Maybe SSD is dying so it will intervene with wd blue because SSD has Win10? HD tune, Crystal disk info, HD sentinel and SSD kingston manager tells me that everything is ok.
Opinions?
Old August 12, 2018, 09:51 AM
KaptCrunch's Avatar
yes fresh OS on new hardware
also check SSD firmware read all doc's on updating firmware
run ASUS Suite and check bio's
current is ROG STRIX X470-F GAMING BIOS 4018 improve system performance 2018/07/20
Old August 12, 2018, 10:33 AM
Shadowmeph's Avatar
check task manager to see which process is using all that juice
Old August 12, 2018, 11:10 AM
It is latest SSD firmware.
I still have stock BIOS, I will upgrade BIOS (didn t upgrade yet because newer version of bios had problems with compatibillity with monitoring software, it freezes) and reinstall windows soon, I still need my PC for work.
it impossible to see because it happens very quickly
So with facts that it stutter on SSD and HDD it seems there is a strong evidence that this is not a disk problem?
I will soon buy RX 580 or GTX 1060 + some WD red for storage so I won`t have any money left for some bigger SSD. Since I bought WD blue ezex from time to time I stumble upon forums posts about that this HDD is no reliable, that it mostly failed after warranty expires and similar negative stuff so I am a little worried that this could be his end...
Old August 12, 2018, 11:49 AM
Shadowmeph's Avatar
oh hang on it is in a game well that is probably the game itself allot of games are very poorly programmed I did a quick search and that game has issues with what you are discribing
Old August 15, 2018, 08:03 AM
yes I saw that on forums they say that game is poorly optimized for ATI cards. I also noticed that it stutters always pretty on the same places. And my old Ati 7770 has 1GB of VRAM which is alwas on the max level of usage on this game
High Memory & Disk?? ModernRevolutions New Builds 19 November 22, 2017 12:55 PM
3dmark 11 High temple - random fps drop on 1080 ti in the same spot. sew333 Video Cards 0 June 23, 2017 10:08 AM
High Ram usage at idle Aspire Troubleshooting 13 December 29, 2016 04:33 AM
Slow disk to disk to transfer rates. CroSsFiRe2009 Storage 3 December 8, 2009 09:01 PM
Disk Boot Failure - Insert system disk and press enter? lanken123 Troubleshooting 5 May 13, 2009 07:23 AM
