Old February 21, 2018, 09:37 AM
Default CF-19 issues
I've recently gotten my hands on a CF-19 in decent condition through work. Can't get into the darn thing though since its running WindowXP, I have no idea what the log-in info is, and none of the back doors I can find are working. So...
I was interested in wiping it and running some kind of a Linux distro on it and was hoping to load it off a USB. Ive gotten as far as getting the thing to USB boot but I can't find a proper install file. I tried ubuntu but it either wasn't the right file set or I'm doing something dumb, possibly a combination of both
Attached is a screen cap of the files I'm using. Thoughts on what I might be doing wrong or what to do here?
Old February 21, 2018, 09:57 AM
Nobody is going to really help with this since you are new and have 1 post. My suggestion is do some google work as there is lots of help for this.
Old February 21, 2018, 10:39 AM
Lysrin's Avatar
As enaberif said, lots of help out there in Google land for this ;) To point you in the right direction to start you need to look for a bootable Linux distro and get that onto your bootable USB and install from there. You should be able to find that in the downloads of nearly any current Linux distro. You have it USB booting, so you are on your way. You have two options usually: installing from the bootable USB to run the OS off the internal drive or running a live version off of the USB media.
Old February 21, 2018, 05:13 PM
JD JD is offline
I would suggest using this: https://unetbootin.github.io/ to create your USB. That should take care of it for you. Then you should just need to boot the laptop from the USB and (hopefully) it'll kick off the install.
Old February 21, 2018, 06:15 PM
KaptCrunch's Avatar
why bang your head
take it back to work an give to IT so they can wipe company passwords
Old February 22, 2018, 07:59 AM
Thanks for the push in the right direction. I'll up date when I've made some progress.
As far as why not take it back to work? That easy and I don't learn by having other people do things for me.
GTX 670 Issues powerbench Video Cards 6 July 9, 2012 04:30 PM
Corsair Issues Warning of Possible H100 Fan Controller Issues SKYMTL Press Releases & Tech News 8 October 1, 2011 03:03 PM
I5 750 issues with OC AbsoluteKyle Overclocking, Tweaking and Benchmarking 2 June 20, 2011 10:50 AM
Mic issues and etc Confetti Troubleshooting 1 June 11, 2010 08:38 AM
MAG (I'm having mic issues with my BT set) Cadence Gaming 0 January 28, 2010 07:14 PM
