Old August 7, 2017, 09:15 AM
sswilson's Avatar
Default W10 - Change default language?
Is it as simple to change from English to French as the online guides make it look?
Looks like it's just a simple change in the regional settings.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
Old August 7, 2017, 11:06 AM
sswilson's Avatar
Wasn't quite as simple as changing the regional settings but it wasn't all that hard to do.
The regional/language settings changed the program/app names but didn't change the system dialogue language. That required installing the language pack from control panel (the same option might be available from the regional settings area, but I did it from control panel).
So you can chalk up another "win" for Windows 10. Pretty sure you had to do a complete re-install of windows 7 to change the default language.
Old August 9, 2017, 11:30 AM
Nutty's Avatar
Trial Member
No,you just had to dl a languagepack,just like win10
Can you change the default install location (program files) draemn O/S's, Drivers & General Software 3 November 9, 2015 01:55 PM
Windows 8 Default Theme fortkentdad O/S's, Drivers & General Software 9 January 13, 2013 07:57 PM
Change Default File Partition For Installing 32-Bit Files on Windows 7 icu222much O/S's, Drivers & General Software 1 December 24, 2012 09:21 PM
Had to OC my ram to get what its default timings were supposed to be... Valamyr RAM 4 August 29, 2011 04:08 PM
DLink DI-524 Language Change Joker Troubleshooting 1 January 3, 2008 03:17 AM
