Old June 21, 2017, 04:38 PM
Caldezar's Avatar
Default Win 10 Home to Pro... How simple?
If I want a laptop that only appears to be available with Windows 10 Home, but I need to convert it to Windows 10 Pro; how simple is it to make that conversion? I already have a Pro key I can use, so is it just a matter of changing they key in the system window? Or would I need to do a whole new install?
Old June 21, 2017, 04:46 PM
sswilson's Avatar
You don't need to do a full install. I just did this with a refurb that had home on it and it worked fine. Pretty sure it's the "change product key or upgrade your edition of windows" selection.
All I did was input a pro eligible key (W7 Ultimate) and it did the rest on the existing "home" install.
Lian-Li PC-011 Air (RGB) / Custom WC / Intel 730 Series 480GB SSD / Intel 760p 512GB NVMe / ASUS SWIFT PG279Q
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Screen
Old June 21, 2017, 08:06 PM
KaptCrunch's Avatar
yes then update with pro key enterd
Old June 22, 2017, 11:33 AM
Caldezar's Avatar
Sweet! I love it when a plan comes together...
Now to decide if the MSI Stealth Pro truly is the laptop for me.
Old June 22, 2017, 04:36 PM
JD JD is offline
Yeah, and if you want to test before buying, just use the default key (a quick Google will find that for you).
Probably simple... gimark Troubleshooting 4 March 25, 2013 03:29 PM
Simple question? BrutalGreen Cases 3 June 24, 2011 01:20 PM
Hopefully A Simple one Soultribunal Troubleshooting 4 March 27, 2009 07:35 PM
Simple Question Scutum_Deus CPU's and Motherboards 8 September 22, 2008 06:31 AM
Who is using nTunes and is there something better thats simple? Canadianguy Video Cards 4 December 3, 2007 08:14 AM
