Old July 20, 2009, 09:16 AM
FreeKnight's Avatar
Default vista and oczvetex ssd issues
Hey everyone,
I'm having a bit of an issue with my vista install. I made a 20 gb patition when I installed vistaa 64 on the ssd. But it won't recognize the rest of the drive in windows unless I format it. But you're ot ssupposed to format an ssd right? What do I do? Its recognized in the bios and the 20gb section works just fine....
Old July 20, 2009, 11:11 AM
Full Speed's Avatar
You can format them. You're not supposed to defragment them if that's what you're thinking about.
Old July 20, 2009, 11:15 AM
gingerbee's Avatar
check in the device manager
Old July 20, 2009, 11:23 AM
Full Speed's Avatar
I believe he found it in device manager, he just doesn't know if he should format it so he can partition it or not.
Old July 20, 2009, 11:32 AM
gingerbee's Avatar
initialize disk and format that's what i would do. and then use partition ha ha
Old July 20, 2009, 07:22 PM
FreeKnight's Avatar
Lol, I knew I was making a stupid mistake somewhere, forgot it was 'no defrag' not 'no format'. Everything is working great and I'll post pics of the new build asap.
Thanks again everyone.
Old July 20, 2009, 07:35 PM
gingerbee's Avatar
good news great to hear
Bootup Issues?!?!? HELP!!! CasheKicker Troubleshooting 16 April 5, 2009 08:36 PM
The Lite-On SATA Blu-Ray drive has known issues with Vista x64. Misoprostol Storage 1 May 26, 2008 05:52 AM
e8400 issues enaberif CPU's and Motherboards 5 February 15, 2008 02:13 PM
reboot issues Jhayman Troubleshooting 7 January 23, 2008 06:00 AM
DailyTech reports that Microsoft issues comprehensive Vista patches to testers Supergrover Press Releases & Tech News 2 July 30, 2007 08:54 PM
