Old July 12, 2019, 01:32 PM
Default Need suggestions for hardware upgrades on my current PC
Hey guys,
I am looking for upgrades for my PC, but I am not sure which part to be upgraded. My PC specs is below. One thing I know for sure I want to change is the power supply since it starts to make funny noises.
Budget is $1000 CAD
This PC is for gaming :D
Thank you for helping
Cheers
Old July 12, 2019, 01:36 PM
Bond007's Avatar
What do you use your computer for? Obviously you CAN upgrade everything, but overall it isn't really lacking anything. Is it not performing a certain task well enough?
If primarily for gaming, I would do the power supply (since you want to), and the graphics card...that is all. Sell the 980 and get a 2060 Super (or 2070 if it is priced similarly...only marginally faster than the 2060 super) to go with your high refresh rate 1440p monitor.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old July 12, 2019, 01:41 PM
Mostly gaming on this one. If I can add a bit more budget, do you think it will be worth it to go for 2080?
Thanks man
Old July 12, 2019, 01:51 PM
Bond007's Avatar
Thanks man
IMO no it isn't worth it. If you feel the need to go bigger you can get the 2070 super, but you are past the point of diminishing returns.
2070 super gets you an extra 20% ish performance for ~40% more $
2080 gets you 25% ish more performance for ~50% more $
At 1440p I don't think it is needed, but if you want more the option is there.
Old July 12, 2019, 02:02 PM
This is great man, thank you for the suggestions !
Old July 12, 2019, 02:27 PM
Bond007's Avatar
No problem...take it for what itís worth. A 2060 super should be almost double the performance of a 980.
Old July 12, 2019, 02:51 PM
sswilson's Avatar
Bond007's suggestion is solid. A top end vid card + a good PSU is going to be pushing the $1000 budget once you factor in taxes, and will serve you well once you feel the need to upgrade your cpu/motherboard.
Lian-Li PC-011 Air (RGB) / Custom WC / Intel 730 Series 480GB SSD / Intel 760p 512GB NVMe / ASUS SWIFT PG279Q
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Screen
Old July 12, 2019, 04:59 PM
Cptn Vortex's Avatar
Yup I agree with the RTX upgrade, but also since they are pretty cheap now, maybe get a 1TB SSD for your OS/Games and use those 250's for laptops or upgrading other older PC's?
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS/USB3.1
i7-5820K @4.4GHZ
RTX 2070
4x8GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
Old July 12, 2019, 07:54 PM
JD JD is offline
If you can push your budget a little, you could potentially do almost a full system overhaul. Something like this for example: https://ca.pcpartpicker.com/list/N9NB8Y
PfSense hardware built suggestions. ShinraCorp Networking 11 November 23, 2017 08:40 AM
Rebuild on current rig (minor upgrades) ToXic New Builds 7 December 4, 2010 03:13 PM
[Help] Home Server Hardware Suggestions MikeFallen New Builds 19 October 16, 2010 05:05 PM
Windows XP and hardware upgrades. chibi_man O/S's, Drivers & General Software 18 January 6, 2008 08:59 AM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 08:53 AM
