View Poll Results: choose the case
FD Midi R2 0 0%
FD Meshify C 4 66.67%
Enthoo Pro/variants 1 16.67%
CM H500P mesh white 1 16.67%
Other, pls specify 0 0%
Voters: 6. You may not vote on this poll
Old October 12, 2018, 08:21 PM
MARSTG's Avatar
Dancing_Banana Case choice for RGB build
i don't know what case to use for my RGB build, i want transparent window and front intake fans.
Needs to accept atx mobo, preferably perforated front intake with 2 or 3 fans, side window.
The window, should it be clear or tinted?
My first stop would be the CM H500P mesh white https://www.newegg.ca/Product/Produc...82E16811119341. Also thinking of Meshify C https://www.newegg.ca/Product/Produc...82E16811352084, or Enthoo Pro https://www.newegg.ca/Product/Produc...69&ignorebbr=1.
FD Midi R2 https://www.fractal-design.com/home/...es/arc-midi-r2 if i can find it used (tc11 looking at you!)
Mobo is already chosen the Gigabyte H270 Gaming 3 https://www.gigabyte.com/Motherboard...ng-3-rev-10#kf
I would also like to use the Cooler Master MasterAir G100M RGB heatsink, the UFO! https://www.newegg.ca/Product/Produc...hoC2EcQAvD_BwE
Old October 12, 2018, 09:24 PM
Dwayne's Avatar
Cases are such a personal thing, you really have to be the one choosing since you have to look at it all the time after!
With that said, I have a Fractal Meshify C, with the dark tint glass. The link you provided showed a lighter tint, which would be really nice I think. I don't have any RGB fans in the front so I can't say how visible they would be, but the inside is nice and clean and was great to build in. It is not as deep as some cases, so depending on your video card and if you want to put a rad in the front, you may want to watch the dimensions.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Samsung - 960 EVO NVMe 500 GB Boot : Muskin 1 TB Reactor SATA : Crucial MX 500 1 TB SATA m.2 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA RTX 2080 XC Ultra Gaming
HTPC - MSI B360-M Gaming Plus : i3 8100 : 8 GB G Skill Ripjaws V Series: EVGA 500W 80plus : EVGA GTX 1050 SC : NMedia HTPC Case: Adata 240 GB SSD Boot
Tablet - Asus Surface clone
Wife's Rig - MSI GL72M 7RDX
Old October 12, 2018, 09:38 PM
MARSTG's Avatar
no rad only air cooling
Old October 13, 2018, 04:21 AM
Bond007's Avatar
I have nothing but good things to say about my midi R2, so if you get a deal on one and like it’s looks, then go for it. Unfortunately fractal hasn’t updated it in some time, so if you go new I would probably go to something else. I voted meshify...it suits my style.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old October 13, 2018, 06:46 AM
MARSTG's Avatar
I already had Midi R2 it looks awesome!
Case choice for 3 GPUs MARSTG Cases 7 June 20, 2017 07:11 PM
New rig, worried about case choice BiscuitBastard New Builds 2 April 16, 2014 10:29 AM
Case Choice playful1510 Cases 37 April 5, 2012 01:30 PM
Looking for new case - Going to oil up tonight need final choice ToXic Cases 24 December 1, 2010 09:36 PM
fan choice for case and cpu cooler help Bobobear Air Cooling 2 December 11, 2009 11:22 AM
