  #171 (permalink)
Old September 27, 2008, 07:13 PM
Brian's Avatar
Dang, just found out that the Vendetta 2 won't fit in the Cosmos S case without interfering with the side fan.
With that said, I'm going to go back to debating between the Antec 1200 and the HAF 932 haha.
I know from reading other threads here that the Vendetta 2 fits in the HAF so that's a plus, but I also like the looks of the 1200 a little better. (Don't get me wrong, not insulting the HAF)
The only thing that might put the HAF 932 on top is the vent for the power supply.
  #172 (permalink)
Old September 27, 2008, 09:24 PM
Well it comes down personal preference, some will prefer HAF 932 and some with the Antec 1200. Since you've heard some of the pros and cons of both cases here, I suggest you go and read couple full review on both cases, look at them very carefully, the features, the goods and bads and then decide. Because if you ask much we will suggest our choice, but it might bot suit you, or you might not like it once you get it..
Sorry, but that would be the best possible way I can see.
  #173 (permalink)
Old September 27, 2008, 09:40 PM
Brian's Avatar
I'm going to go with the Antec 1200.
The main selling feature for me is the extra optional fan on the side as well as the fan that can be mounted inside...both of which can be used to cool down the video card. There seems to be sufficient airflow in the case and previously in this thread it has been stated many times that either case will do nicely. So either way I can't really go wrong. Plus the looks please me more, and so does the price hehe.
  #174 (permalink)
Old September 28, 2008, 12:20 AM
They are both about the same price range, actually the HAF 932 is just about $15 cheaper. Not contradicting on your choice, I'm sure you made the best possible choice. The Look of the 1200 is definitely more pleasing, HAF looks like a sick person with bandages on the hospital bed lol :P..
  #175 (permalink)
Old September 28, 2008, 11:36 PM
Lithotech's Avatar
Actually, it looks sort of like a gas can from a M*A*S*H hospital.
eVGA 680i SLI (A1) P31
Intel Q6700 Kentsfield | Scythe Ninja-B | Antec Tri-Cool 80cfm
4GB (4x1024MB) Corsair Dominator 8500
boot: 4x WD Caviar SE16 250gb SATA2 Raid-0
backup: Seagate 500gb 32mb SATA2
eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz
candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA
juice: PC Power & Cooling 750Quad | Cooler Master HAF932
steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's
  #176 (permalink)
Old September 29, 2008, 05:09 AM
The CoolerMaster MASH 932!
ASUS P5Q-E - E8400 (4GHz) - Corsair TX650W - 2xHIS HD 4850 IceQ Turbo - 2x2GB Mushkin Ascent 8000 - 2xWD 500GB - TRUE 120 - Antec 1200 - ASUS Xonar DX - Big Smile
  #177 (permalink)
Old September 29, 2008, 06:36 AM
Lithotech's Avatar
A cammo paint job would look great on it!
  #178 (permalink)
Old September 29, 2008, 06:39 AM
Lithotech's Avatar
Think it comes with the side panel fan.
When it boils down this close, looks count for a LOT! If you prefer the look of the 1200, then that's it!
Be sure to point us to the build thread when you get your parts! Gratz, and good luck!
  #179 (permalink)
Old September 29, 2008, 10:42 AM
Brian's Avatar
Haha CoolerMaster MASH 932.
Here are the final specs everything picked out and the final purchase that will be made tonight or tomorrow. (Posting it here for revision and to see if anyone spots any incompatibilities.)
Board:
Asus P5Q Deluxe
Processor:
Intel Core 2 Quad Q9550 2.8Ghz w/ OCZ Vendetta 2, Scythe S-FLEX 1600RPM
Memory:
Mushkin XP PC2-8500 4GB 2X2GB DDR2-1066 CL5-5-5-15 dual channel
Hard Drive:
Western Digital Caviar SE16 640GB
DVD Drive:
Samsung SH-S223F
OS:
Vista Home Premium OEM 64bit
PSU:
Corsair HX1000w
GPU:
HIS Radeon HD 4870x2 2GB
Monitor:
Samsung 2443BW-HAS 24IN Widescreen LCD Monitor
Fan Control:
Sunbeam Rheobus Extreme Black 5.25IN 6 Fan Controller Blue LED Up to 30W Per Channel
Case:
Antec Twelve Hundred with stock LED fans, 2 Noctua P12 fans (1 for the side panel, 1 for the internal GPU cooling behind the HD cage)
Mouse:
Logitech G5
Mouse Pad:
Razer eXactMat Mouse Pad & eXactRest Wrist Rest Bundle Dual Sided Mousing Surface
Keyboard: (Already owned) Logitech G11
I hope that's everything and I hope there are no compatibility issues or else I'm screwed.
Thanks for all your help guys and I will surely point you towards the build thread once started!
  #180 (permalink)
Old September 29, 2008, 12:21 PM
sswilson's Avatar
Don't forget to get some thermal compound. (MX2 or AS5)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
