Old May 8, 2019, 04:45 AM
Default Where to find manual for an ASUS K501L laptop?
Hello,
I am trying to get into the bios setup of an ASUS K501L laptop. I am hitting either the "delete key" or "F2", but it is not working accessing the bios setup. Anyone know where I can find the manual to download? I tried a Google search and a search at ASUS without any luck!
I
Thank you,
CG
Old May 8, 2019, 12:21 PM
ipaine's Avatar
Quick question, are you running windows 10?
If so then as long as you can get into the OS you can get to the BIOS without issue (well in theory).
Just hold the shift key when you select restart from either the start menu or right from the logon screen. As long as you hold shift it will bring you to a separate menu that should give an option to restart in the UEFI settings. Pick that and it should reboot right into the BIOS/UEFI.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
https://www.evga.com/associates/defa...CUV5OY6FY0U02O
Old May 8, 2019, 12:43 PM
FreeKnight's Avatar
Originally Posted by Chess Gator View Post
Hello,
I
Thank you,
CG
Try;
https://www.asus.com/Laptops/K501LX/HelpDesk_Manual/
Trying to find a tablet/laptop for my father. ShinraCorp Mobile Computing 4 March 10, 2016 11:20 AM
Asus HERO manual OC?? SAS Overclocking, Tweaking and Benchmarking 14 October 3, 2013 02:29 PM
Help me find a laptop! Rison Mobile Computing 6 February 24, 2013 08:46 PM
Help Meeeee find the laptop i want to buy gingerbee Mobile Computing 4 February 27, 2012 06:14 AM
ASUS develops manual GPU overclcoking tool Babrbarossa Press Releases & Tech News 1 July 5, 2007 09:34 AM
