Old April 10, 2019, 11:27 AM
Default Lightweight and tough power AC cable extension
When travelling being mobile, I use a thick tough blue outdoor 3 prong extension cable. It is kinda heavy.
It is ten feet and just long enough for my needs.
I am looking for something lighter.
What do you guys use to power a laptop? Max 200wats I think is good
Gone mobile and back to Gaming to LEARN! :p
Laptop: Dell G5 i5-8300H, 16GB, 1050 4GB, Samsung EVO 970 500GB+EVO 860 500GB, Microsoft Sculpt Comfort Mouse
Gaming PC: i7-2600K, 32GB, EVGA 1070 8GB, Crucial BX500 250GB, WD 4TB, ASUS Xonar DX playing just CS:GO and some StarCraft 2
HTPC/Server: See "My System Specs". I also use it to virtualize an instance of Windows to my mobile devices.
Graphics Designer and Tech Journalist @ www.RealHardwareReviews.com ID: eyetrance
Old April 10, 2019, 11:54 AM
sswilson's Avatar
Walmart has a black stanley 3 plug (3 prong) extension that's not rated for appliances, but should be more than enough for a laptop. Added benefit is the flush mount socket design.
https://www.walmart.ca/en/ip/stanley.../6000197241024
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
Old April 10, 2019, 12:01 PM
JD JD is offline
Depending on the connector, you could just get a longer cord?
Couple examples:
https://www.amazon.ca/TNP-Universal-.../dp/B01HPWIGXS
https://www.amazon.ca/StarTech-com-P.../dp/B006DJ2OA6
hd audio header extension cable QuickDeath Audio 1 February 24, 2012 06:25 PM
Looking for 8Pin Motherboard Power Extension Cable Your_friendly_gamer Power Supplies 7 October 11, 2011 06:17 PM
Extension cable power requirements: What is safe? chrisk Power Supplies 14 August 14, 2010 06:42 PM
3.5mm extension cable: Does quality matter? Scart Audio 6 August 30, 2009 10:17 PM
extension for usb motherboard cable quikgp Peripherals 9 May 13, 2009 10:53 AM
