Old January 12, 2019, 05:17 PM
sswilson's Avatar
Default Disadvantages to undervolting mobile processors?
Just completing the finishing touches on my poor man's gaming laptop (Dell G3) and finally got around to using XTU to play with the VCore offset and found that changing the offset to -.125 does indeed drop temps down enough to prevent thermal throttling under full load. (Dropped between 15 - 20C off of the max temps on my i5-8300H and seems to be keeping my max under full load to mid 80s).
I know some of our members have played with undervolting so I'm wondering if they've ever encountered a downside (aside from instability from going too low) to undervolting?
If not.... then anybody running a laptop should be checking for thermal throttling under stress testing and dropping their VCore offset down a few points using XTU.
Thoughts?
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old January 12, 2019, 05:26 PM
Bond007's Avatar
There are absolutely zero downsides as long as it is 100% stable. Lower power draw/heat at a fixed freq, or higher freq for the same power/heat. The factory voltage has a buffer to account for variances in silicone....you just have to play to figure out how much of that buffer you can remove on your specific cpu.
I have undervolted (and overclocked at the same time) every CPU I have owned in the last 8 years. My new laptop will just be an undervolt though, since it is locked.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old January 12, 2019, 08:08 PM
JD JD is offline
I think ThrottleStop is the recommended way to undervolt rather than XTU as I don't think it's officially supported on laptops.
But yeah, definitely the way to go, especially with gaming laptops.
Question about Undervolting a GTX 480 blueem2 Overclocking, Tweaking and Benchmarking 1 November 2, 2012 04:12 PM
Disadvantages 2500k + z77? DMCdejavu CPU's and Motherboards 3 August 24, 2012 11:56 AM
Seagate Debuts Mobile Wireless Storage for iOS and Other Mobile Devices SKYMTL Press Releases & Tech News 0 May 16, 2011 09:03 AM
Asus P6T undervolting my system?? akulacan CPU's and Motherboards 7 February 26, 2011 12:50 PM
Undervolting CPU Kilauea CPU's and Motherboards 6 August 12, 2009 12:45 PM
