Old December 21, 2018, 03:01 PM
Shadowmeph's Avatar
Default where to look for cheap laptops
I posted on the rants about my mothers accer laptop keyboard failing so I am going to try and get ahead of this and start searching for decent laptop that is maybe 400 CAD and under she only using it for emails web surfing and the occasional youtube video the screen should be minimal 15" should be windows based although years ago I gave her a older laptop which I had Linux installed on it and she loved it . just as long as it is point and click . the Accer she has is pretty much everything attached which I really wished that she would have came to me before she went out I cant even remove that battery on it I think that it is part of the system I am not sure but I really didnt want to start pulling things apart .
Old December 21, 2018, 03:25 PM
JD JD is offline
Would 14" work? Though I hate 1366x768 resolution. This: https://www.dellrefurbished.ca/lapto...50-169215.html is otherwise pretty decent for $373.
They have 15" as well, but no SSD and same resolution: https://www.dellrefurbished.ca/lapto...50-172886.html
You could also get a Chromebook instead if she doesn't need Windows: https://www.bestbuy.ca/en-ca/product...13018565.aspx?
Old December 21, 2018, 03:40 PM
MARSTG's Avatar
ebay is full https://www.ebay.ca/itm/Dell-Latitud...IAAOSwB5lb6khq
Old December 21, 2018, 04:00 PM
sswilson's Avatar
As has already been suggested... an off lease business class laptop would be where I'd look first.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
Old December 21, 2018, 04:30 PM
Shadowmeph's Avatar
thanks people :) going to check those out.
Old December 21, 2018, 05:02 PM
3.0charlie's Avatar
refurb.io
Hydro-Quebec is salivating...
Old December 21, 2018, 05:07 PM
sswilson's Avatar
refurb.io
Pretty sure that's where I got my first E6420, but I was also happy with the E7440 I got from Dellrefurb (keep an eye out on RFD for their sales which are often 30% or more).
Old December 22, 2018, 08:53 AM
sswilson's Avatar
https://www.visions.ca/catalogue/cat...T430I54GB128GB
You'd probably want to upgrade to 8GB minimum, but that's a pretty decent price for a third gen i5 from a known retailer.
Old December 22, 2018, 09:32 AM
JD JD is offline
3rd gen i5's, especially mobile, are pretty weak.. we've gotten rid of all the T430s at work as they were becoming too slow. I would suggest getting a 5th gen CPU (or higher) if you can afford to.
What's out there for cheap laptops? Brian Mobile Computing 6 January 20, 2015 09:36 AM
[FS] 780i, 2x2gb ddr2 1066, q9550 cheap! cheap! cheap! kyle_L Buy/Sell & Trade 16 November 24, 2009 08:05 AM
