  #21 (permalink)
Old January 2, 2019, 03:40 PM
Mr. Friendly's Avatar
yes, gaming notebooks get warm...hot even, but when gaming it's likely to be on a desk/table, not your lap, so heat isn't an issue unless there is serious CPU throttling going on.
  #22 (permalink)
Old January 3, 2019, 02:23 PM
rjbarker's Avatar
Originally Posted by fubar View Post
Aren't laptops hard to cool? If you use them for gaming, don't they get hot or warm? I suspect the fans get loud?
I would recommend an ITX build if you want to game and have it somewhat mobile. The only negative for that is that you have to connect a display but how different is that with some notebooks that are 'hybrids' - acting as tablets with the screen detachable?
At least, with some itx builds, you can install discrete graphics cards of your choice (for the most part - within limits). Yes, those are hard to cool, too, and you might have noise but I suspect it's easier to deal with than notebooks - probably cheaper, too?
Try and put an ITX build in a Swiss Brief Case ...we're talking "portable" as in hotel rooms...at work (work out of town).....need to be able to transport it in a brief case....
they get toasty but new (especially MSI / ROG) are built for this....I recommend sticking to a 15" vs a 17" ....lighter and more portable...set-up an aggressive fan speed for your GPU .....my ROG Asus runs all new titles on the 1070M very well at Med to High settings 1920 *1080....GPU reaches and settles at around 75c - 82c .....dont notice the fan noise much as your usually wearing head phones or ear buds.....
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
  #23 (permalink)
Old January 5, 2019, 05:50 PM
I am a seriously interested in this bad boy.
https://www.asus.com/ca-en/Mini-PCs/...C-ProArt-PA90/
Mah Rig now
Mah Rig before
My stuff for sale.
  #24 (permalink)
Old January 6, 2019, 02:42 PM
rjbarker's Avatar
Pretty funky looking!!!
Timespy: 18.613K
MARK 11: 40.185K
  #25 (permalink)
Old January 7, 2019, 08:36 AM
but that's not a notebook, LoL!
  #26 (permalink)
Old January 7, 2019, 09:06 PM
It's so damn close though
Mah Rig now
Mah Rig before
My stuff for sale.
any point to allow compression on primary 128GB SSD TedShackley Storage 5 February 3, 2012 04:56 PM
Help in determining primary SSD Seeps New Builds 5 January 22, 2011 04:00 PM
SSD How to merge unallocated partition to primary partition in Windows 7 Mark Troubleshooting 22 May 14, 2010 04:32 PM
Best sub $500 notebook? m0pelley99 Mobile Computing 19 August 23, 2009 03:34 PM
